Power windows nightmare
#796051
03/11/07 06:40 PM
OK it's not really a nightmare, but one of my power windows is toast. The window stopped going up or down, and I finally got around to taking the door apart and looking inside. Yikes.
It seems the cable that actuates the window is jammed up, and a little white plastic cable run broken. I tried what I could, but nothing did anything, so for now duct tape is the only thing keeping the window up.
Can these be fixed, or is it common to get a whole new door at a junk yard or something?
BH
Re: Power windows nightmare
[Re: BigHornE]
#796052
03/11/07 08:11 PM
I had the same problem with the cable and broken white plastic peices, I just replaced the window regulator that is complete with the track,cable, ect. Cost about $100 and about an hour to instal. I ordered from an online parts store.
93 Rodeo 4x4 3.2 auto Tinted Windows SuperWinch hubs Full Kenwood audio system Indy4x 3" lift, SS brake lines, HD tie-rods, DOR diff drops & UB skidders, Procomp ES3000's
[Re: josh93rodeo]
#796053
03/11/07 09:32 PM
That doesn't sound so bad, but how did you get 'in there' to install all the bits and pieces? I can barely fit my fingers in there. I'm sure there must be a trick, because my bleeding knuckles were pretty useless.
BH
[Re: BigHornE]
#796054
03/12/07 10:45 PM
I too have had the same problem. As I recall it didn't take very long to replace either. Also paid under $100 shipping included.
1995 Trooper LS (OME Coils & 2" spacer, Rancho 9000, Nitto Terra Grappler 34", K&N, ARB Snorkel, Calmini Rear Bumper) In garage (9000 winch, custom S. America winch bumper, Delta Cams, Tera-Low 3.07)
[Re: TrooperMark]
#796055
03/16/07 03:01 AM
Its not as bad as it seems once you dive into it. You can get a chiltons manual to help you along.
94 Rodeo 3+3 lift Red) 95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2 front winch bumper custom rear bumper, Hella 500's 2004 Silverado duramax
