snapped sway bar quick disconnect bolt wheeling in Crozet #796100 03/11/07 07:20 PM
TrailMystic Offline OP
I wheeled in Crozet, Virginia yesterday. It's really a different experience to wheel a course that is intentionally set up to create obstacles. I felt a little out of my league, but I finished without too much carnage. I didn't disconnect my front sway bar because the cheap replacement CV axle binds up on full droop. Big mistake - the bolt sheared off the sway bar quick disconnect (should be easy to fix). It was a non-stop, white knuckle experience all the way, and I thought I had managed to get through without body damage. Then, the last 50 feet of the course (the only flat 50 feet) I went through a puddle and a hidden branch in the water leaped out of the water and slapped my rear panel denting it. It's like the course said, "No one leaves without SOME damage."
Pete
'01 Rodeo Sport, 5 Speed Softie, Indy 4X rocker bars, OME 912's, Rancho 9000X's, Superwinch hubs, custom tube bumper with Warn 9000i , Flowmaster 50, TeraLow t-case gears, ARB front & rear lockers, TrXus MT's, Sway bar disconnects
Re: snapped sway bar quick disconnect bolt wheeling in Crozet [Re: TrailMystic] #796101 03/12/07 01:37 AM
V
Veronica99 Offline
If your sway bar quick disconnects are from Rock Stomper, I would not bother to try to fix them. I broke mine three times just driving, and had them professionally rewelded together twice. After the third break, I just scrapped the entire sway bar. Drives just fine now.
I am not saying that Rock Stomper makes cheap stuff, I think that the angles for the links are just too much.
Dreaming of an SAS
Re: snapped sway bar quick disconnect bolt wheeling in Crozet [Re: Veronica99] #796102 03/12/07 03:25 AM
matthew Offline
NOPE...they are Independent4x and fully supported <img src="/forums/images/graemlins/wink.gif" alt="" />
just bring it by pete and swap them out for new...............you are the 1st to break....conradulations <img src="/forums/images/graemlins/lol.gif" alt="" />
crozet is a good prooving ground..........good job wheeling there w/ out a break of some kind.
'93 RS 3.2L - DD/trail build
'97 7.3L Powerstroke - tow rig
'71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build
Owner: http://www.INDEPENDENT4x.com
m-f 9am-6pm EST. 804-550-0480
Re: snapped sway bar quick disconnect bolt wheeling in Crozet [Re: TrailMystic] #796103 03/13/07 08:04 PM
Matt already made me a replacement (no cost). Carnage happens. <img src="/forums/images/graemlins/shiner.gif" alt="" /> The product is very high quality and I recommend it highly.
Pete
Re: snapped sway bar quick disconnect bolt wheeling in Crozet [Re: TrailMystic] #796104 03/14/07 01:41 AM
W
Wareagle Offline
I agree about the qualkity of the product. I added a set on rear axle. Its now super flexy <img src="/forums/images/graemlins/smile.gif" alt="" />.
Re: snapped sway bar quick disconnect bolt wheeling in Crozet [Re: Wareagle] #796105 03/15/07 05:06 AM
Jeff Mason Offline
You just broke a bolt?? HEck I snapped the entire Sway bar last fall on a piddly little dirt road on the way to a trail <img src="/forums/images/graemlins/smile.gif" alt="" />
Jeff Mason
Whatever makes you upset in someone else...also exists in you
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6101 MB (Peak: 0.6807 MB) Data Comp: Off Server Time: 2026-06-23 04:00:19 UTC
