Black smoke #796113 03/11/07 08:17 PM
Pajerist Offline OP
Noticed bad black smoke from exhaust pipe <img src="/forums/images/graemlins/scared.gif" alt="" />, after changed gasket set in the fuel pump, fuel filter changed as well.
What it could be?
Thanks <img src="/forums/images/graemlins/cheers.gif" alt="" />
Fight for Right to drive from Right!
www.ivoac.ca
Stay away from Nic's Garage at 120 West 1st Ave in Vancouver BC!!!
Re: Black smoke [Re: Pajerist] #796114 03/11/07 11:13 PM
redbull Offline
When are you getting smoke? A little on hard acceleration, at startup, or all the time?
Some smoke can be normal, I hear. I get none however. Lots of black smoke means unburned fuel, so it could be running rich. Look on the POCUK site for info on turning down the fuel pump. Who did your pump seals? From what I've read, you generally need to get a pump calibrated after it's been worked on.
Re: Black smoke [Re: redbull] #796115 03/12/07 02:01 AM
Pajerist Offline OP
I drove behind my Pajero and I believe, when my brother shifted the gear and then a little bit with acceleration.
Here http://www.maxoverdrive.ca/ changed the gasket set. I would not recommend to go to them. Who needs a reason, please send me a private message and I'll tell you.
Put local diesel for 20 bucks and it started!
With Japan fuel, with leaking fuel pump it was not at all!
Cheers, <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Black smoke [Re: Pajerist] #796116 03/12/07 04:25 AM
redbull Offline
A little bit of smoke under acceleration only could be normal. The leaking pump might not have been delivering full pressure, so less fuel. Now, with the repaired pump, you have a rcher mixture.
That's all guessing, not much else to do over the internet. If it really bothers you, take it in to a diesel specialist.
Re: Black smoke [Re: redbull] #796117 03/12/07 06:43 AM
torquemonster Offline
my pajero smokes black lots too, only under hard(ish) acceleration and everytime I let the clutch out in 1st gear it leaves a little cloud. black means "partially" unburned fuel, blue is totally unburned fuel, you'll notice on a cold morning its blue. greyish white smoke means burning oil.
Re: Black smoke [Re: torquemonster] #796118 03/12/07 07:29 AM
redbull Offline
I get none. So little that I'm considering turning up the mix a touch.
Re: Black smoke [Re: redbull] #796119 03/13/07 06:22 AM
yah..all I have for exhaust is 2.5" turbo back system and a resonator. no catalytic converer or muffler. it barks pretty good too. and holy hell can I hear the turbo through the exhaust.
Re: Black smoke [Re: torquemonster] #796120 03/13/07 08:02 PM
PartyTruck Offline
<img src="/forums/images/graemlins/kewl.gif" alt="" /> The only way to do it
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: Black smoke [Re: PartyTruck] #796121 03/13/07 10:04 PM
I would like to upgrade it to 3" eventually but I can't justify me actually needing it haha. I would like to cut back on the smoke a little bit, maybe I'll just crank the boost up more.
Re: Black smoke [Re: redbull] #796122 03/14/07 06:11 AM
Pajerist Offline OP
I did and it is OK now <img src="/forums/images/graemlins/kewl.gif" alt="" />
Thanks for your info <img src="/forums/images/graemlins/cheers.gif" alt="" />
www.ivoac.ca
PHP: 7.4.33 Page Time: 0.016s Queries: 16 (0.013s) Memory: 0.6359 MB (Peak: 0.7607 MB) Data Comp: Off Server Time: 2026-10-27 22:57:01 UTC
