Stripped Tranny Drain
#796246
03/12/07 03:59 AM
Crap. Either I stripped out the auto tranny drain hole and the metal stuck to the bolt or I stripped the bolt. Anyone have any idea what size the replacement bolt is? Anyone strip the pan and come up with a fix that doesn't involve replacing the pan, better yet not even having to drop the pan? Someone said there are oversize self tapping pan bolts but not much luck on a Sunday.
1997 T-100 4X4 Xcab,Warn Hubs 02 Camry LE 2008 Yaris
Re: Stripped Tranny Drain
[Re: garym]
#796247
03/12/07 04:58 AM
You should be able to take the bolt to a hardware store like Lowe's or Home Depot and check the size on it... I know that Lowe's usually closes at 8pm on Sunday... <img src="/forums/images/graemlins/wink.gif" alt="" />
I'll have to find my FSM and see what it lists fer the 1993 tranny bolt... <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: garym]
#796248
03/12/07 03:35 PM
Most parts stores carry a replacement plug made of a rubber material that has a wedged screw assembly in the rubber. You turn the screw with an allen wrench and the plug expands into the threads. They have been around forever. They work like a drywall anchor does.
trafdlo
[Re: garym]
#796249
03/14/07 04:06 AM
Lucked out this time. There were enough threads left to grab the new bolt and it sealed. FYI: xmission drain bolt part # 90341-10011 and it is a 10M 1.50 threads. Auto Xmission Pan, if you have to go that far is Part # 35106-35022. That's for a 4x4. I don't know if the 2WD is the same.
[Re: garym]
#796250
03/28/07 02:43 AM
I've had this happen on a couple of my trucks before. (not my doing) I have found that the bolt is softer than the threads, at least in my cases. I cleaned up the threads in the pan and installed the new bolt with no problems.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6040 MB (Peak: 0.6684 MB) Data Comp: Off Server Time: 2026-06-21 19:17:35 UTCValid HTML 5 and Valid CSS
