22re valve adjust #796459 03/13/07 01:16 AM
1
1986xtracab Offline OP
Have any of you tried adjusting your valves cold? I know they are supposed to be adjusted while hot but it seems by the time i get to the end its just not hot anymore.
1986 xtra-cab 22re
stock everything
1991 bed
Re: 22re valve adjust [Re: 1986xtracab] #796460 03/13/07 01:22 AM
kewlynx Offline
I set my drag a little to the heavy side. This has been visited recently; the difference isn't worth obsessing over. <img src="/forums/images/graemlins/cheers.gif" alt="" />
**ubi apis- ibi salus**
Re: 22re valve adjust [Re: 1986xtracab] #796461 03/13/07 01:35 AM
87Toy4x4 Offline
if youre stock set them at .008 intake and .012 hot. when setting cold, set them at .007, .011.
Re: 22re valve adjust [Re: 1986xtracab] #796462 03/13/07 04:46 AM
yotaman7 Offline
kewlynx is right. Here is a link to the previous post on this topic.
Link
"4X4 in upper case is $X$" Quoted from http://4crawler.com/4Runner.shtml
'00 tacoma 4WD---Sold to Toyota
'93 pickup 2WD
'85 pickup 4WD
Re: 22re valve adjust [Re: yotaman7] #796463 03/13/07 06:15 PM
ChrisH Offline
I adjusted mine to .007 / .011 warm and they quieted down a fair bit. I'd be careful doing this though, don't want to burn ur vavle seats.
One thing i've heard (and this is speculation/hear-say, I haven't tried it out yet myself) is that if you over tighten your valve cover cap-nuts you can effectively loosen your adjustments.
It kind of makes sense because the studs are threaded into the rocker ass'y and when you tighten down against the valve cover (which pushes against the head) you're sucking those studs upward, thus pulling on the rocker ass'y.
The hole in that theory is the headbolts hold the rocker ass'y down, and those're torqued right in. So who knows. A tech at a Toyota dealer gave me this tidbit of info. I have yet to try it. Mine aren't that loud and it runs great so I'm not too worried. Rather not have oil all over my engine bay <img src="/forums/images/graemlins/shiner.gif" alt="" />
'95 Toyota Pickup DX Xtended Cab ~ Daily Driver
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.6054 MB (Peak: 0.6694 MB) Data Comp: Off Server Time: 2026-11-11 22:25:35 UTC
