V6 Transfer case question
#796606
03/13/07 07:01 PM
I would like to do a duel case set up on my '88 4Runner with a 22RE. My question is I have a '88 V6 transfer case lying around and was wondering if I could use the gear reduction off of it.
Re: V6 Transfer case question
[Re: thorn4run]
#796607
03/13/07 07:58 PM
Toyota Moderator
Unfortunately no one manufacturers parts to use the chain driven V6 transfer case for dual cases. You will need to find another four cylinder case or buy one from a vendor like Inchworm or Marlin.
[Re: DirtyHarry]
#796608
03/13/07 08:27 PM
I thought just the part that turns the drive shafts was chain driven. So your saying the gear reduction part is worthless also. What a bummer!
[Re: DirtyHarry]
#796609
03/13/07 08:30 PM
Unfortunately no one manufacturers parts to use the chain driven V6 transfer case for dual cases. You will need to find another four cylinder case or buy one from a vendor like Inchworm or Marlin. I saw a discussion on Marlin's board stating he had one... but I can't find it. Blackdog is running one; might be the prototype: http://board.marlincrawler.com/index.php?topic=30155.0
Brian K. Gallus I have nothing important to say.
[Re: bkg]
#796610
03/13/07 11:51 PM
Blackdog is running one; might be the prototype: I know he makes one for the 3.4 C-drive t-case, did not know he was making one for the 3.0 C-drive T-case. When I talked to him about it years ago, he told me the 3.0 case was junk. He may have changed his mind.
"Serenity through Sobriety"
[Re: OOP'S]
#796611
03/21/07 11:33 PM
Blackdog is running one; might be the prototype: I know he makes one for the 3.4 C-drive t-case, did not know he was making one for the 3.0 C-drive T-case. When I talked to him about it years ago, he told me the 3.0 case was junk. He may have changed his mind. More info: http://board.marlincrawler.com/index.php?topic=5756.0
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6069 MB (Peak: 0.6770 MB) Data Comp: Off Server Time: 2026-06-03 01:45:37 UTCValid HTML 5 and Valid CSS
