body lift!!!!!!!!!!! #796612 03/13/07 08:16 PM
drewdaddy Offline OP
I am in the process of trying to lift my 88 toyota p/u. Are 3" body lifts ok for my truck??? Or will I have to move and modify anything!! I am really wanting to put 34" or 35" tsl's on my truck!!! Do you think they will clear on this much lift, or is more needed?? I live in florida (no rocks) so I need something for mud.. Any input will be appreciated!!!! I am working on a budget, so I really want to stay away from suspension for now. Also do you think I will have to cut my truck in anyway??? I will be running a 9.5-10.5 tire on a 8" rim. I know I don't have a lot of power, so I am trying to get the width down.
88 P/U EFI 4x4... Stock for now.. 05 Corvette MN6 Z51 Package
Re: body lift!!!!!!!!!!! [Re: drewdaddy] #796613 03/13/07 08:30 PM
4Crawler Offline
Read all about the install process on the page below:
http://www.4crawler.com/4x4/ForSale/Docs/BodyLift_HowTo.shtml#Taller
Probably will need a bit more lift or fender trimming to clear the tires, but try it and see.
Re: body lift!!!!!!!!!!! [Re: drewdaddy] #796614 03/13/07 08:42 PM
thorn4run Offline
I have a 2" body lift and 34" Swamper LTB's on my '88 4Runner. The hardest part with lifting the body was lengthening the steering shaft to the steering box. The front hard lines for the brakes have to be moved around to make up for the lift. With 2" it didn't take much but with 3" you might have to unclip them from the body. The tires rubbed on the fenders and fender wells a bit so I just trimmed the fenders and hammered back the inner fender well.
Re: body lift!!!!!!!!!!! [Re: 4Crawler] #796615 03/13/07 09:01 PM
bkg Offline
whatever you choose to do, definitely buy the kit from Roger. Best in the biz.
Brian K. Gallus
Re: body lift!!!!!!!!!!! [Re: thorn4run] #796616 03/13/07 09:11 PM
i kind of thought 3" might be a little too much... I don't want to have to move a lot around. Now nobody makes any body lifts that come with the extention for the steering??? As you can see, I am new to this... I know some say they come with "EVERYTHING" needed. Is this a joke???
Re: body lift!!!!!!!!!!! [Re: bkg] #796617 03/13/07 09:11 PM
who is roger, how do I get a hold of him??
Re: body lift!!!!!!!!!!! [Re: drewdaddy] #796618 03/13/07 09:22 PM
thorn4run Offline
I just remembered one thing about the 2" lift is the filler hose for the gas tank does not have to be extended. The steering shaft is two parts, one inside of the other; this makes it collapsible in an accident. You just have to drive out a small pin and pull the shaft longer and drill a new hole to put the pin back in.
Re: body lift!!!!!!!!!!! [Re: thorn4run] #796619 03/13/07 09:26 PM
2" sounds like a better option!! Anyone know what is the largest tires I can put on my 88. I am guessing 31 x10.50??? even though i would like bigger ones. i have a lot of questions being new to this. Can anyone point me in the direction of what size tires are stock on this truck (mine are different sizes) and where I can calulate what gears i will need with new tires??? I tried the search on here, but it doesn't seem to work very well (or it could be user error)
Re: body lift!!!!!!!!!!! [Re: drewdaddy] #796620 03/13/07 09:29 PM
bkg Offline
First person to respond to your initial post; Roger Brown, aka 4Crawler. Makes the best body lift kits in the industry, IMHO.
Brian K. Gallus
Re: body lift!!!!!!!!!!! [Re: drewdaddy] #796621 03/13/07 09:33 PM
4Crawler Offline
31x10.50 will fit stock:
- http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml#FAQ10
Gearing vs. tire size:
- http://www.4crawler.com/4x4/4R_TechInfo.shtml#DiffRatios
Steering shaft extension:
- http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml#RecircBallExt
- http://www.4crawler.com/4x4/ForSale/Docs/BodyLift_HowTo.shtml#RecirculatingBall
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6430 MB (Peak: 0.7625 MB) Data Comp: Off Server Time: 2026-06-23 13:40:33 UTC
