engine dies.
#796841
03/13/07 10:31 PM
after running 15 mins it dies changed fuel filter still dies 89 jeep 6cyl
Re: engine dies.
[Re: tking]
#796842
03/13/07 10:50 PM
And then??? Ok so it dies.. are you still in the driveway? Does it restart? What are it's dying gasps? Popping, crackeling? Smoking? Enlighten us. Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: engine dies.
[Re: BigJim]
#796843
03/21/07 04:04 AM
Not to sound rude, but why do so many people assume "fuel filter" when a vehicle dies? That filter would have to be plugged shut in order for the engine to not receive fuel, which is HIGHLY unlikely. That's the last thing I'd consider. The coil could be overheating, which is a common problem with faulty ignition modules. No spark = no start, obviously. They overheat and literally shut off.
Re: engine dies.
[Re: tking]
#796844
03/22/07 01:54 AM
if there is no spark, most likely causes would be a failed ignition module. if the engine won't crank, you are probably dealing with a jeep starter or battery problem.
PHP: 7.4.33 Page Time: 4.348s Queries: 18 (0.005s) Memory: 0.6142 MB (Peak: 0.7170 MB) Data Comp: Off Server Time: 2026-06-21 01:33:07 UTCValid HTML 5 and Valid CSS
