Thinking of buying a Reman. Engine #796958 03/14/07 04:31 PM
RalkClimber Offline OP
Well.. after all my hard work.. I just decided to purchase a remanufactured engine. Found a local place that will sell me an engine for $1199 with 3yr warranty..
My main seals are out and other issues compression etc... I think it's a good deal. Local shop will rebuild my engine valve job, bore block.. for $1500. only 1yr warranty..
Think i'm making a good decision.. Your thoughts?
Ralk
'97 Jeep Wrangler 2.5L 105k Miles
Recent Replacements: Cam Shaft, Lifters, Push Rods, Distributor, Dist. Cap/button, Plugs, Oil Pump, Oil Sending Unit, Timing Chain/sprokets, and all associated gaskets.
Re: Thinking of buying a Reman. Engine [Re: RalkClimber] #796959 03/14/07 08:05 PM
BigJim Offline
RC a good deal depends largely on who you are. Be very particular about the heads.. Do you get new rockers and balls? Do you get new guides? Do you get new pushrods?
How about the valves themselves?
The block is the least of my worries in a rebuild. Most machine shops can bore and install the needed parts quite easily.
I ALWAYS have the machine work done to the block and use the machine shop to order the parts I LIKE for the block.
Then I get the head work done and install new rockers and balls and pushrods myself.
Don't overlook the top end, that is the week link in a rebuild.
Re: Thinking of buying a Reman. Engine [Re: BigJim] #796960 03/15/07 02:28 AM
new rockers, push rods, timing chain, cam, oil pump, valves/guides.
18 month warranty unlimited miles.
Ralk
Re: Thinking of buying a Reman. Engine [Re: RalkClimber] #796961 03/15/07 04:16 AM
BigJim Offline
Go for it.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.007s) Memory: 0.5993 MB (Peak: 0.6549 MB) Data Comp: Off Server Time: 2026-11-01 15:57:39 UTC
