Re: S10 vortec swap into a 91 toyota [Re: matts] #797019 03/18/07 06:17 AM
dcg9381 Offline
Lots of web info on this swap.. Pretty common and well documented and you can use existing driveline as people make adapters.
I'm not a fan of GM TBI, although it is better than a carb, it's just a mild step up. Get the port injected VORTEC motors. Just do your research, as mentioned all the odds and ends do add up to real money.
22REturbo.net
1988 4Runner
Re: S10 vortec swap into a 91 toyota [Re: bkg] #797020 03/18/07 11:16 PM
Baldy Offline
If you are going to swap a non toyota engine might as well go with the small block Chevy 350. I swapped a 91 small black 350 into my 82 D-50 4x4. Spent about $1,300 doing it, including the adapter, engine, transfer case and tranny. I just did ALL the work. The power and torque of the V8 is awesome. A huge increase in power.
Re: S10 vortec swap into a 91 toyota [Re: fringefan] #797021 03/19/07 01:35 AM
kewlynx Offline
I almost forgot about Supra swaps; also relatively common
Rick's mod
If you check the last post if the pix aren't there anymore, Rick had sent me links for the project that you can springboard from. <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6002 MB (Peak: 0.6536 MB) Data Comp: Off Server Time: 2026-06-10 06:14:54 UTC
