Re: S10 vortec swap into a 91 toyota
[Re: matts]
#797019
03/18/07 06:17 AM
Lots of web info on this swap.. Pretty common and well documented and you can use existing driveline as people make adapters.
I'm not a fan of GM TBI, although it is better than a carb, it's just a mild step up. Get the port injected VORTEC motors. Just do your research, as mentioned all the odds and ends do add up to real money.
22REturbo.net 1988 4Runner 22RTE core, turbocharged, megasquirted...
[Re: bkg]
#797020
03/18/07 11:16 PM
If you are going to swap a non toyota engine might as well go with the small block Chevy 350. I swapped a 91 small black 350 into my 82 D-50 4x4. Spent about $1,300 doing it, including the adapter, engine, transfer case and tranny. I just did ALL the work. The power and torque of the V8 is awesome. A huge increase in power. ![[Linked Image]](http://img.photobucket.com/albums/v204/baldy110/Rubicon06/Rubicon06137.jpg)
[Re: fringefan]
#797021
03/19/07 01:35 AM
I almost forgot about Supra swaps; also relatively common Rick's mod If you check the last post if the pix aren't there anymore, Rick had sent me links for the project that you can springboard from. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5978 MB (Peak: 0.6511 MB) Data Comp: Off Server Time: 2026-06-17 02:52:59 UTCValid HTML 5 and Valid CSS
