belts on 95 sr #797182 03/15/07 05:22 AM
mountain_warrior Offline OP
i gotta change the belts and lookin at it i cant tell if there is an easier way to do it without taking the radiator out any ideas???
1988 swb montero/pajero
1995 sr montero
Re: belts on 95 sr [Re: mountain_warrior] #797183 03/15/07 05:26 PM
bOURGE Offline
If you need more room once the tension is relieved remove the fan.
1995 Montero SR
1999 Montero
1974 Ford Bronco
Re: belts on 95 sr [Re: mountain_warrior] #797184 03/15/07 05:41 PM
W
Winston Offline
You do not need to remove the radiator to replace any of the belts. It is possible to remove the fan and fan shroud without removing the radiator.
'90 Montero XLS (Sold, sadly)
'95 Montero LS 160k
'03 Montero Limited 30k
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5912 MB (Peak: 0.6443 MB) Data Comp: Off Server Time: 2026-06-06 19:38:01 UTC
