Re: switching to OME coils,stock rear springs welded??? [Re: Kingrya] #797258 03/18/07 01:47 AM
reran Offline
With the shocks unbolted, there is just enough room to remove the old springs and squeeze in the new springs. As previously stated, be mindful of the brake lines. Also, you can disconnect the sway bars for additional space to remove & replace the coil springs. HTH.
94 Trooper S, 3.2 SOHC, Auto, Aisin's, OME 912's, TBC, Indy 4x HD TRE, Tokico shocks, AR Outlaw II's 16x8, Bridgestone Revo's 265/75x16
89 Trooper S, 2.6, auto, work in progress
Re: switching to OME coils,stock rear springs welded??? [Re: reran] #797259 03/18/07 03:48 AM
BigSwede Offline
I have OME coils and 2" spacers with the stock brake lines, so you shouldn't have a problem if you pay a little attention. But if you do want to upgrade your brake lines, Independent4x has some nice braided steel ones for Isuzus...
Serenity now!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5954 MB (Peak: 0.6433 MB) Data Comp: Off Server Time: 2026-05-29 23:42:45 UTC
