brake fluid #797358 03/15/07 11:01 PM
O
oldgreen Offline OP
Kind of odd, but when I checked the brake fluid the rear part for the disc brakes was overfull and the front part for the drum brakes was half full. I corrected it and when it was checked again today the same thing. Could it be a faulty master cylinder? Or possibly the proportioning valve. It is an 84 cj7 with a 304.
84 CJ7 304 HEI 35 BFG,s rear dana 60 with detroit locker,Viar compressor, fibreglass body, 2 1/2 spring lift, TF999auto, Warn 8000 winch, Plus a cool little trailer on 35,s. JEEP stands for just empty every pocket
Re: brake fluid [Re: oldgreen] #797359 03/16/07 12:29 AM
BigJim Offline
Perhaps you should bend down and look at the inside of the front tires.. You just may have a wheel cylinder leak..
Re: brake fluid [Re: BigJim] #797360 03/16/07 03:08 AM
O
oldgreen Offline OP
Thanks Jim for the sage advice, I did just that and no leaking cylinders, somehow the the fluid from the small front part of the master cly seems to wind up in the larger rear part of the master.
Re: brake fluid [Re: oldgreen] #797361 03/16/07 03:40 AM
BigJim Offline
OG if you fill them both to the top, how can it go to the back wihtout having a fluid loss?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5994 MB (Peak: 0.6547 MB) Data Comp: Off Server Time: 2026-06-18 20:49:39 UTC
