304 v-8 #797520 03/16/07 03:18 PM
sroyfire Offline OP
Ihave a 84 CJ-7 4.2 I-6 with a auto trans. Will a 304 V-8 bolt up to my trans? How hard would it be to do this conversion? <img src="/forums/images/graemlins/patriot.gif" alt="" />
'07 Jeep JK 2" Pro Comp Skyjacker shocks 17" Pro comp wheels 295/65-17 Pro Comp Xtreme A/T
'84 CJ-7 2" lift 32x11.5 pro comp
LETS WHEEL
Re: 304 v-8 [Re: sroyfire] #797521 03/18/07 09:13 PM
superdawg Offline
That tranny is a 904 or 999 torqueflight. It will bolt up but...that trans is not built for v8 power.
I believe it can be beefed to handle a v8.
SD
Re: 304 v-8 [Re: sroyfire] #797522 03/19/07 07:27 AM
BobRowe Offline
The TF999 can be beefed up fairly easy with a heavy duty kit. Unless you're into auto trannies, it will cost you some to get it done at a shop.
I have a TF999 behind the AMC 360 V8 in my CJ. The only problem I had initially was burning the narrow clutch ring in the torque converter. That contaminated the tranny fluid, which screwed up the tranny. When I had the tranny rebuilt with the heavy duty parts (and the torque converter replaced), I had the operating line for the locking clutch clamped off, so it never locks now. That costs me about 10% in fuel mileage, but it'w worth it to me not to have to worry about it.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5923 MB (Peak: 0.6451 MB) Data Comp: Off Server Time: 2026-06-06 18:54:58 UTC
