OK need some help here. #797538 03/16/07 07:58 PM
O
Omega Supreme Offline OP
1987 toyota 4x4 22re. I parked my truck for about 2 weeks. Went out to fire it up and nothing. Lights worked, some things did not. I found out that the 80 amp fuse next to the battery had blown. How did that happen? Anyways throw a new one in and it fires right up. Let it run for about 15 minutes. Shut it off. Next week i need my truck, nothing again, this time no lights no nothing. I checked all the fuses by my battery, they all are fine. I havnt checked the ones on my kick panel but will. How do i keep popping fuses when my truck is just sitting?
Re: OK need some help here. [Re: Omega Supreme] #797539 03/16/07 11:48 PM
O
bUMP
Re: OK need some help here. [Re: Omega Supreme] #797540 03/17/07 01:46 AM
O
Ok so i went and checked out all of my fuses. A ok. What could this be, a bad ground, its been sitting in the garage for a month, it started a week ago. My battery has juice, i cant even get my clock to come on. Any help would be great. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: OK need some help here. [Re: Omega Supreme] #797541 03/17/07 02:17 AM
CJM Offline
some times just "rotating" / "moving" the positive post clamp on the battery works ..
sometimes there can be a build-up/neg clamping on the post... IF the battery is left in there .
83 Trekker SR5
NEW Trekker forum
Re: OK need some help here. [Re: CJM] #797542 03/17/07 02:31 AM
Scerb Offline
Make sure you test the 80A fuse with a multi-meter. I've had it blow before and it still looked perfectly ok. As to why your're blowing fuses, I have no idea. I would imagine some sort of a short somewhere <img src="/forums/images/graemlins/confused.gif" alt="" />
-Scerb
Re: OK need some help here. [Re: Omega Supreme] #797543 03/17/07 04:19 AM
Davepet Offline
THere should be a fusible link before the under hood fuse box, check to see id you have *any* power at the box.
Once you find the problem start checking with the ohm meter to try & isolate what's causing it.
Dave
Re: OK need some help here. [Re: Davepet] #797544 03/17/07 08:34 PM
DRTDEVL Offline
A common short location causing the 80 amp fusible link to blow is the o2 sensor wire melting on the exhaust. Look there first.
PHP: 7.4.33 Page Time: 1.229s Queries: 15 (0.004s) Memory: 0.6167 MB (Peak: 0.6907 MB) Data Comp: Off Server Time: 2026-06-05 23:25:07 UTC
