Thrust washers in locker #797547 03/16/07 10:57 PM
Z
zachtheterrible Offline OP
A friend of mine helped me install my first aussie locker in the front, but he didn't put thrust washers in, and I didn't know what was going on.
I just finished putting in 4.88's and another aussie locker in the rear and I realized what happened. Is this something I should really be worried about, worth pulling the whole thing apart again? I never hear the front ratched like the rear, but it's worked fine, I think . . .
1984 Toyota Pickup
22R, carbureted
Aussie lockers front n rear
4.88 gears
35's
Full exo
Marlin crawler
Re: Thrust washers in locker [Re: zachtheterrible] #797548 03/17/07 04:08 PM
A
AussieLocker Offline
Thrust washers must be reinstalled for a proper installation and for the warranty to be valid. Also, he needs to follow the installation manual with regard to the spacer to cross shaft and the innercam spacing, again for proper operation and warranty. If he has any questions on this contact us at engineering@aussielocker.com
Re: Thrust washers in locker [Re: zachtheterrible] #797549 03/17/07 07:38 PM
dcg9381 Offline
I made the same mistake one with an Aussie. The result was a perma-locked rear end and wearing of the pins on that locker. IT definitely needs to be pulled apart and likely will need the pins/springs replaced. Not expensive, but driving it like that isn't a good idea.
22REturbo.net
1988 4Runner
PHP: 7.4.33 Page Time: 2.743s Queries: 15 (0.010s) Memory: 0.5928 MB (Peak: 0.6464 MB) Data Comp: Off Server Time: 2026-07-17 04:57:02 UTC
