Manual trans wont go into any gear
#797845
03/18/07 04:25 AM
Not familar with transmissions and need some advise. I have a v6 transmission that wont shift, just has side to side (neutral)Dont know what to do.
88 Mitsu Van (L300) 90 Mitsu Eclipse GSX 95 Mitsu Montero SR w/285/75/16 torsion bars cranked about 1.5" 04 Mitsu Lancer Ralliart 81 Datsun 280ZX 96 Dodge Cummins Turbo Diesel (316hp/815ft.lbs)
Re: Manual trans wont go into any gear
[Re: triplediamonds]
#797846
03/18/07 04:53 AM
I would start by taking the shifter stick outr,and see what that looked like in there.but I,m by no means a tranny mech.
oh what a feeling: #1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered #2 86 sr5 4x4 efi parts truck #3 87 2wd parts truck 84 supra yard art
#797847
03/18/07 10:41 AM
J Roll Me Over
Check the fluid in the clutch master cylinder
[Re: DRTDEVL]
#797848
03/18/07 03:00 PM
Second that, check the clutch hydraulics. Check under the peddles to see if there is any brake fluid (brake fluid is used in the clutch master cyl). If there is any fluid it means your clutch master is leaking. Cheap and easy fix if this is the case.
Keep the Shiney Side up. Support our troops.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6008 MB (Peak: 0.6558 MB) Data Comp: Off Server Time: 2026-06-16 08:31:37 UTCValid HTML 5 and Valid CSS
