...why isn't there a temp control system that allow outputs fer active cooling/notification? Something just like yer house thermostat. Not only will it tell you the temp but when the sensor reaches a certain temp, turn on a cooling fan or/and an alarm/flashing light. Kind of like set it and fergit about it!
The thermostats in your coolant and fan clutch already do exactly that. Engine-overheat is extremely uncommon on these trucks unless there are other problems, at which point the "id10t" light and/or temp guage lets you know you need to stop and do some diagnostics. The ECU also monitors temps and this info can be accessed via the OBDII system with a laptop or code reader if you want "real time" data.
Aftermarket tranny coolers have been proven to help keep the tranny temps under control and are almost a necessity on these trucks. Aftermarket temp guages are available and are not a bad idea to have to help keep an eye on things. And there are tranny coolers available with thermostats that bypass the cooler except when needed and/or turn on a fan as well.
200*F is a fairly low temperature for your brakes. Brake fade occurs when the fluid starts to boil. DOT 3, 4, and 5.1 fluids have dry boiling points of over 400, 450, and 500*F, respectively (but is reduced with water contamination). Aftermarket fluids can raise this further (and provide better resistance to water contamination) and things like slotted rotors can help keep the temps from getting as high in the first place. The rotors themselves are already "fans," and I don't think adding additional fans would help much except maybe at low speeds. And they would also put more load on the engine via the alternator, not to mention the extra weight.
I was reading that Raylin website. There appears to be a lot of scare tactics and misinformation going on there. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
These are some interesting ideas, but I really don't see the need. <img src="/forums/images/graemlins/confused.gif" alt="" /> Some of it comes down to common sense and/or knowing how to use your vehicle safely and properly (not driving too fast, turning off OD when the tranny starts hunting, downshifting instead of overusing your brakes, etc.) to avoid some of these problems in the first place, and there are already products available to solve some of the other problems.
