Page 15 of 20 1 2 … 13 14 15 16 17 19 20
Re: New addition to the Family..89SWB Auto [Re: justice] #798661 03/21/09 09:24 PM
Oyaji_Jon Offline
Don't sweat it. Whenever you get a chance. Take care and good luck with the op...
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: New addition to the Family..89SWB Auto [Re: Oyaji_Jon] #798662 03/22/09 08:11 PM
Oyaji_Jon Offline
J, what radiator did you end up using, and is it working good? The Raider is running a bit hot and I want to get the right one to rod out...
Thanks.
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: New addition to the Family..89SWB Auto [Re: Oyaji_Jon] #798663 03/23/09 12:55 AM
justice Offline OP
Jon, I backflushed mine and soldered up a leak myself. It's been working good since, but I still want to replace it. I replaced the fan clutch and that made a big difference. I also rigged an extra switched AC fan for crawling.
Re: New addition to the Family..89SWB Auto [Re: justice] #798664 03/23/09 06:42 AM
Oyaji_Jon Offline
Ok, I've got to do something. Thanks. I'm trying to find the thread I started on mine to lay out the initial impressions of the black one.
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: New addition to the Family..89SWB Auto [Re: justice] #798665 04/07/09 03:48 AM
Glock24 Offline
I'm not a native English speaker, so maybe blueprint was no the best word to use :P
Well, what I wanted was some measurements, some instructions on how to build the mountings so it is stronger than the factory bumper, and maybe some kind of diagram.
Looks good. I'll give it a try when (and if) I have the time.
Blue print:
Buy 2"x 5" tube, 2" x 2" tube, cut and bend, weld. Use your truck as a template to adjust to your measurements. Use 2" wide flat bar stock to box up the openings. Use angle iron for the mounts to the frame. Order some shackle tabs from a fab shop and weld those on.
Grind, then grind some more, sand, primer, filler primer, light sand, paint black.
Thats pretty much it in a nutshell. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Not laughing to be an <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> I just dont have any blue prints as I've pretty much just winged it using my 89 as a mock up to ensure a good fit. Hope this helps, the progress pics should give you a good idea
'98 Galloper II Exceed 2.5TDI LWB 5sp Manual 5.29 Diffs
Re: New addition to the Family..89SWB Auto [Re: justice] #798666 04/07/09 06:39 AM
Oyaji_Jon Offline
Jon, I'm out on a training op in the desert right now. I meant to take the pics before leaving but things got a little messed up when I had to get a new garage door put on at thevlast minute. Hopefully I'll be able to sneak home and take a pic for you soon.
J, you back at the house? Any chance of a pic of that frame notch? If not, no problem. Whenever you get around to it...
Thanks,
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: New addition to the Family..89SWB Auto [Re: Oyaji_Jon] #798667 04/08/09 01:21 AM
justice Offline OP
Jon, Im still out here in the sand supporting WTI near Yuma AZ. I might be able to get home next weekend but that is still up in the air...Its up to the old man to decide if we are going to get any libo.
Re: New addition to the Family..89SWB Auto [Re: justice] #798668 04/08/09 03:26 AM
Oyaji_Jon Offline
No problem, brother. Thought you were back at the hacienda already. No rush, take care out there!
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: New addition to the Family..89SWB Auto [Re: Oyaji_Jon] #798669 04/15/09 06:36 PM
justice Offline OP
OK jon here are the pics of the frame notch finnally:
Overall view cut an L shaped notch in the front of the frame horns. This retains the stock captive mounting bolt holes on the sides of the frame rails.
side view cut 1 3/4" back :
Front view: cut 1 3/8" down:
Dont forget this is for the 2" body lift. PLH you will need to cut strait down since you have no BL.
Re: New addition to the Family..89SWB Auto [Re: justice] #798670 04/15/09 06:42 PM
justice Offline OP
Sorry for the delay..I've been out on an operation. Willwinchforfood, the snorkle template will be sent back your way shortly.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6572 MB (Peak: 0.7672 MB) Data Comp: Off Server Time: 2026-11-16 01:31:38 UTC
