Re: New addition to the Family..89SWB Auto
[Re: justice]
#798661
03/21/09 09:24 PM
Don't sweat it. Whenever you get a chance. Take care and good luck with the op...
73 -Jon KJ6GVM As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter Grampa's Trooper 1974 FJ40 1987 FJ60
[Re: Oyaji_Jon]
#798662
03/22/09 08:11 PM
J, what radiator did you end up using, and is it working good? The Raider is running a bit hot and I want to get the right one to rod out...
Thanks.
[Re: Oyaji_Jon]
#798663
03/23/09 12:55 AM
Jon, I backflushed mine and soldered up a leak myself. It's been working good since, but I still want to replace it. I replaced the fan clutch and that made a big difference. I also rigged an extra switched AC fan for crawling.
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
[Re: justice]
#798664
03/23/09 06:42 AM
Ok, I've got to do something. Thanks. I'm trying to find the thread I started on mine to lay out the initial impressions of the black one.
[Re: justice]
#798665
04/07/09 03:48 AM
I'm not a native English speaker, so maybe blueprint was no the best word to use :P Well, what I wanted was some measurements, some instructions on how to build the mountings so it is stronger than the factory bumper, and maybe some kind of diagram. Looks good. I'll give it a try when (and if) I have the time. Blue print:
Buy 2"x 5" tube, 2" x 2" tube, cut and bend, weld. Use your truck as a template to adjust to your measurements. Use 2" wide flat bar stock to box up the openings. Use angle iron for the mounts to the frame. Order some shackle tabs from a fab shop and weld those on.
Grind, then grind some more, sand, primer, filler primer, light sand, paint black.
Thats pretty much it in a nutshell. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Not laughing to be an <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> I just dont have any blue prints as I've pretty much just winged it using my 89 as a mock up to ensure a good fit. Hope this helps, the progress pics should give you a good idea
'98 Galloper II Exceed 2.5TDI LWB 5sp Manual 5.29 Diffs
[Re: justice]
#798666
04/07/09 06:39 AM
Jon, I'm out on a training op in the desert right now. I meant to take the pics before leaving but things got a little messed up when I had to get a new garage door put on at thevlast minute. Hopefully I'll be able to sneak home and take a pic for you soon. J, you back at the house? Any chance of a pic of that frame notch? If not, no problem. Whenever you get around to it... Thanks,
[Re: Oyaji_Jon]
#798667
04/08/09 01:21 AM
Jon, Im still out here in the sand supporting WTI near Yuma AZ. I might be able to get home next weekend but that is still up in the air...Its up to the old man to decide if we are going to get any libo.
[Re: justice]
#798668
04/08/09 03:26 AM
No problem, brother. Thought you were back at the hacienda already. No rush, take care out there!
[Re: Oyaji_Jon]
#798669
04/15/09 06:36 PM
OK jon here are the pics of the frame notch finnally: Overall view cut an L shaped notch in the front of the frame horns. This retains the stock captive mounting bolt holes on the sides of the frame rails. ![[Linked Image]](http://homepage.mac.com/zone1wst/.Pictures/wheelin/framecut1.jpg) side view cut 1 3/4" back : ![[Linked Image]](http://homepage.mac.com/zone1wst/.Pictures/wheelin/framecut2.jpg) Front view: cut 1 3/8" down: ![[Linked Image]](http://homepage.mac.com/zone1wst/.Pictures/wheelin/framecut3.jpg) Dont forget this is for the 2" body lift. PLH you will need to cut strait down since you have no BL.
[Re: justice]
#798670
04/15/09 06:42 PM
Sorry for the delay..I've been out on an operation. Willwinchforfood, the snorkle template will be sent back your way shortly.
