Re: really bad gas mileage!!!! [Re: 89PU] #798890 03/22/07 12:16 AM
hdrisc Offline
incorrect timing will also decrease mileage
Re: really bad gas mileage!!!! [Re: hdrisc] #798891 03/22/07 12:46 AM
CJM Offline
How's the fuel pressure?
I didnt think fuel perssure was an issue ??? ( I could be wrong) but that is what the return line is for ? ..
thinking it could be a "leak down" proplem .. I also replace the cold start injector .
timing is right on .
83 Trekker SR5
NEW Trekker forum
Re: really bad gas mileage!!!! [Re: CJM] #798892 03/22/07 01:17 AM
canuck Offline
What about the TPS adjustment then followed by the timing. This was my problem when running rich. Also caused my cat to plug up.
Keep the Shiney Side up. Support our troops.
Re: really bad gas mileage!!!! [Re: canuck] #798893 03/22/07 01:29 AM
CJM Offline
have followed the steps to set up in in manual ..
83 Trekker SR5
NEW Trekker forum
Re: really bad gas mileage!!!! [Re: veach] #798894 03/22/07 01:59 AM
V
veach Offline OP
ok when i said rebuild i ment just a engine rebuild and the question about if it happend suddenly or over time the answer to that is it happend suddenly because i was gettin better gas mileage before i rebuilt it. but thank u guys very much for your info i will let u know what works
Re: really bad gas mileage!!!! [Re: CJM] #798895 03/22/07 02:57 AM
8
89PU Offline
high pressure can result in a rich mixture when running in open-loop mode
Re: really bad gas mileage!!!! [Re: 89PU] #798896 03/22/07 05:46 AM
G
Greg_Canada Offline
Corey what brand O2 sensor did you use?
89 4Runner
Re: really bad gas mileage!!!! [Re: Greg_Canada] #798897 03/22/07 03:49 PM
CJM Offline
I guess thats my next step .
I dont remember , but it was an aftermarket NOT oe ..
I did replace it with a couple of "cleaned" OE sensors I had on my shelf , and there was no change . It is the single wire O2.
83 Trekker SR5
NEW Trekker forum
Re: really bad gas mileage!!!! [Re: 89PU] #798898 03/23/07 02:55 AM
Frank Torres Offline
Low fuel pressure will result in a poor spray at the injectors thus also resulting in a rich condition.
I would verify fuel pressure...
1991 FJ 80 Land Cruiser for fun.
1998 GS300 for the wife
1998 GS400 for me
1991 Supra SOLD
1986 4Runner 335k miles-22re EB inside.SOLD
Re: really bad gas mileage!!!! [Re: veach] #798899 03/23/07 03:56 AM
O
oldsub86 Offline
Is your rebuild stock or did you change things in the engine?
1995 V6 SR5 5 speed 4X4 - 4Runner - dark blue
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6384 MB (Peak: 0.7420 MB) Data Comp: Off Server Time: 2026-07-17 03:58:44 UTC
