Two quick questions. #799036 03/21/07 06:56 AM
mike1985 Offline OP
1. Is it possible to change the gearing to achieve better highway/ mileage performance? I occasionally drive as far as Utah.
2. I am ready to change my belts, hoses etc. How much tension should I apply to the belts?
Thanks guys, I have learned a great amount of information from all the great posts. I read them every week.
1985 montero 2.6 bigger tires and stuff. im never gonna sell this thing. My buddies joke and call it the crockyyyy car.
Re: Two quick questions. [Re: mike1985] #799037 03/21/07 11:50 AM
JAVYPRO Offline
To your #1, you can always try to go to lower gears but it first will be a pain in the <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> well I am not certain at all so can't help you there.
#2 don't do it to tight, you should have about 1" of slack when you push on the belt.
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: Two quick questions. [Re: mike1985] #799038 03/21/07 03:34 PM
CapnCrunch Offline
5.29 Supply Contact
Check the above link for contact info.
If you just simply want better gas mileage to get from point A to point B I'd suggest getting a used Geo Metro, Subaru Justy, Honda Civic CRX, or Suzuki Swift. I've bought two Metros for dirt cheap and they're extremely miserly on gas and easy and cheap to maintain. It would be cheaper to pick up a car like one of these than to get the gears mentioned above and have them installed.
That being said, I love my 5.29 differential gears. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Despite having a 2.6 and 33s, I get about 17-ish MPG on the highway (I never really narrowed that down because I don't drive it to work often), spend most of my time in the fast lane, and hills are no problem. Bear in mind that unless you don't ever plan on using 4WD, you'd need to swap out the ring and pinion gears in both the front and rear diffs.
If you did decide to go that route, I'd also suggest swapping out the front diff with one from a Gen I V6. Doing so does two things: it positions you for the option of installing a front ARB locker down the road if you so choose, and it also gives you a stronger gearset. Your current front diff is 7.25" while the Gen I V6 front diff is 8". Much stronger.
If you swapped out the front diff and then want the 5.29 gears you'd order two sets of the MB241981 ring and pinion set since both front and rear diffs would then be 8" diffs.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
PHP: 7.4.33 Page Time: 2.371s Queries: 15 (0.003s) Memory: 0.5959 MB (Peak: 0.6494 MB) Data Comp: Off Server Time: 2026-05-30 13:35:55 UTC
