Stearing Gear
#799153
03/22/07 02:39 AM
While changing out the shocks, noticed that stearing gear was dripping. Both seals are leaking. I've been quoted $289 for the part. (remanufactured) That sound right? Anything special I need to change it out besides a pittman arm puller?
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD.
Re: Stearing Gear
[Re: DBL_DTY97TJ]
#799154
03/22/07 03:36 PM
Sounds about right...
Question for anyone: Has anyone ever just tried replacing the seals? I saw a repair kit on the internet for $10. I have the seal leaking at the pitman arm. <img src="/forums/images/graemlins/confused.gif" alt="" />
Ralk '97 Jeep Wrangler 2.5L 105k Miles Recent Replacements: Cam Shaft, Lifters, Push Rods, Distributor, Dist. Cap/button, Plugs, Oil Pump, Oil Sending Unit, Timing Chain/sprokets, and all associated gaskets.
Re: Stearing Gear
[Re: RalkClimber]
#799155
03/22/07 06:57 PM
I'll see how feasible that looks when I take it off. Could be a while though - just bought good shocks, water pump, and reverse light switch ($120!!). Any more spending goes to the house reno work. Keep topping up the power steering fluid till it dies. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Stearing Gear
[Re: DBL_DTY97TJ]
#799156
03/23/07 04:38 AM
I replaced the seal on the back of the steering gear where the steering shaft goes in- pretty basic seal swap. never messed w/ pitman seal.
'80 CJ7; bored 258, weber, MSD, centerforce, rancho 2 1/2 lift, 32" BFG
