Backspacing on wheels #799330 03/23/07 01:10 AM
Monty n Guate Offline OP
Hey guys,
A question about backspacing.
First off I imagine that backspacing refers to what the amount of space from the center of the wheel to the edge of the wheel. Is this correct?
Second. I am lifting a 97 Taco about 2.5 inches and placing 32 x 11.50 ATs on it. The wheels I have purchased have 3.75 inches of backspacing assuming the above is correct. Will these wheels give sufficient clearance for my tires and suspension components up front?
Thanks
Don Iler
97 4cyl. Tacoma
OME 881s, N91s, Alcan AALs, Rancho 9k rear shocks
4.56 gears
32x11.50 Procomp ATs
Re: Backspacing on wheels [Re: Monty n Guate] #799331 03/23/07 07:57 AM
humanoid Offline
You might rub on those 32s. As for the backspacing, I think you need to get 4.5. I'm unsure about the backspacing, but that sounds about right. I'm sure someone more knowledgeable than I will correct me if I'm wrong.
Re: Backspacing on wheels [Re: Monty n Guate] #799332 03/23/07 03:42 PM
Jeff the marmot Offline
Sort of - depending on what you mean. Offset is related to the halfway point of the wheel and whether it's positive or negative -- offset is the more complex of the measurements and gets a lot of people confused. Backspacing is the more simple (and usable) measurement from the edge of the wheel to the mounting surface. So a smaller backspacing will make the tires stick out more, which gives more clearance between tires and suspension components, but you might risk the tires rubbing more at the rear of the front wheel wells during cornering.
Someone else will know about the exact tire/wheel/vehicle combination you have, but what you're trying to accomplish with those wheels sounds about right to me. You will probably need to get out the big hammer for the body seam in the front wheel wells.
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5914 MB (Peak: 0.6448 MB) Data Comp: Off Server Time: 2026-06-18 09:15:41 UTC
