Gen I to Gen II compatability thread
#799886
03/25/07 01:12 AM
This may fall into the catagory of the drivetrain Bible but I feel the subject warrants its own thread. Anyways I think it would be good to have as a quick reference, as to what gen II parts will fit on the gen I and what mods if any are needed to make the swap, along with the know benifits or drawbacks.
So Far this is what I know:
Upper Control arms, direct bolt on will allow for correction of camber with a tortion bar crank.
Rear trailing Arms, Increased durability.
Coil Springs,
Rear Axle on coil spring (V6) models, has anyone done this swap and does the increase in width have affect on rubbing of tires during articulation? Is a custom drive shaft required if installing a 3.5SR locked axle into a GenI 3.0? Anyways I hope some others chime in with their swaps and findings.
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
Re: Gen I to Gen II compatability thread
[Re: justice]
#799887
03/25/07 01:14 AM
Upper Control arms, direct bolt on will allow for correction of camber with a tortion bar crank. Also helps with cv shaft angle. Side affect of better camber.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT gen 2 coils,Cranked front tbars Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
[Re: justice]
#799888
03/25/07 01:17 AM
this would help out alot i have gen1 and gen2 and im always looking for parts for both...this might fall under a seats cat. http://www.4x4wire.com/forums/showf...&o=&fpart=1&vc=1 (i dont know how to make links <img src="/forums/images/graemlins/lol.gif" alt="" />)
1988 swb montero/pajero 1995 sr montero
[Re: mountain_warrior]
#799889
03/26/07 01:51 AM
Anybody try gen 2 tortion bars on a gen 1? Those that swapped to a rear axle with locker from a 3.5 SR gen 2, what were the issues you encountered?
[Re: justice]
#799890
03/26/07 01:58 AM
Justice, Sparky should be able to answer that...
1997 Montero SR
<a href="www.georgiaoverland.com" target="_blank">www.georgiaoverland.com</a>
[Re: DavidG]
#799891
04/05/07 03:36 AM
Gen 2 two pot front brakes on a Gen 1: Kinda... ![[Linked Image]](http://www.tlarengineering.com/images/garage/mitsubishi/Montero/gen2knuckle02.jpg) ![[Linked Image]](http://www.tlarengineering.com/images/garage/mitsubishi/Montero/gen2knuckle04.jpg) Upper arm and steering tie rod needs to be shortened, other than that it fits great! <img src="/forums/images/graemlins/drunk.gif" alt="" />
'87 Mitsubishi L300 - LR4 4.8 swap in progress '87 Chrysler Conquest TSi '93 Honda CRX - Open 4wd rally car
[Re: StarionGTO]
#799892
04/05/07 12:55 PM
Sorry, I must have missed this thread first time around. I swapped in sway-a-way torsion bars from a 93SR in to my 91. Bolted right up, no problems. I also swapped in a 95SR rear axle into my 91. On the rear arms at the frame mount, you have to use the gen1 bushings, they are different. Everything bolted up. I swapped the rear drive shaft flange and Ujoint onto the gen1 drive shaft. I have not put many miles at all, my transmission crapped out 35-50 miles after the swap. <img src="/forums/images/graemlins/evil.gif" alt="" /> From what I did drive, the disc brakes in the rear helped.
GTO, so the front brakes bolt up? I want to do that to my gen1.
[Re: sparkem]
#799893
04/05/07 01:35 PM
GTO, that's really cool. I'll be doing the same swap in a couple weeks when I part my Gen 2 out. <img src="/forums/images/graemlins/kewl.gif" alt="" />
I'd be really interested to know exactly what you mean by what's too long so I can plan ahead. Thanks!
Brendan
1999 Mitsu Montero - Crappy Weather 1992 Isuzu Pickup - Zombie Apocalypse 2008 Saturn Sky Redline - Nice Weather
[Re: 87Montero]
#799894
04/05/07 02:22 PM
It looks like GTO swapped the full knuckles and is finding excessive positive camber as a result. I have not looked but can the gen2 lower arm swap over to make a wider track and correct the camber?
How about a swap with just the rotor and caliper?
I can not wait till my gen2 comes out of the snow it is hiding in so I can get back to working on it.
[Re: OldColt]
#799895
04/05/07 03:53 PM
I was interested in the rotor/caliper swap.. good to know the rest bolts up.. I will have to look into the lower control arm also since I hear that the torsion bars from a G2 bolt up. I'm afraid of how wide it will make the front though.. I am already cutting it close with the low backspacing on my wheels, and I'm at the legal limit without having fender flares. Only a month and half to go.. I'll be graduated.. and can have a field day swapping parts between my Gen 1 and 2. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Anyone know how much a frame on a Gen 2 is wider than a Gen 1 in the rear? I think I might do what OKRED did back in the day and weld a new back end of the frame on my '87.. it's the only way to save it I think, and would it be too crazy to have an 94 SR rear frame on an 87? <img src="/forums/images/graemlins/smile.gif" alt="" />
