Page 2 of 10 1 2 3 4 9 10
Re: Gen I to Gen II compatability thread [Re: 87Montero] #799896 04/06/07 02:06 AM
StarionGTO Offline
Correct, I swapped the entire knuckle over. The result was LOTS of positive camber and LOTS of toe out. You might be able to shim the upper arm to correct for the camber, but you'll lose down travel since the pivot will be inside the frame.
I think it would be safe to say that you could bolt a gen 2 rotor to a gen 1 hub, but I can't speak for the caliper. Calipers might swap between the V6 knuckles, but not the 4 cyl that I have.
Its hard to make out the stock 4cyl knuckle on the driver's since its in the shade, but the steering wheel is centered.
Re: Gen I to Gen II compatability thread [Re: StarionGTO] #799897 04/06/07 02:34 AM
sparkem Offline
I just want to swap calipers onto my gen1.
Re: Gen I to Gen II compatability thread [Re: sparkem] #799898 06/19/07 05:44 PM
justice Offline OP
OK So it looks like lordtrunks confirmed the Front brake calipers from a Gen 2 will swap over with brake line modification. This most likely only applies to 6 cyl gen 1's.
Re: Gen I to Gen II compatability thread [Re: sparkem] #799899 06/19/07 06:01 PM
Happy Birthday hazy_daze Offline
Sorry to hear about your tranny <img src="/forums/images/graemlins/frown.gif" alt="" /> Did you see in the parts bin, a guy in MS has a tranny he's trying to sell?
Good to see this thread. The one I started is apparently too narrow in scope. There is alot more interest in figuring what all parts will retro into GenI's from GenII donors.
Re: Gen I to Gen II compatability thread [Re: hazy_daze] #799900 06/19/07 08:00 PM
justice Offline OP
Confirmed swap: Gen 2 Locking Rear axle Assembly Complete into 89V6 Auto SWB
Donor: 96SR
Direct bolt in. Use the SR Diff side flange Yoke and U-joint and mate it to the gen1 driveshaft. Use the Swaybar off the gen 1 if you want to retain it.
Benefits: rear disk brakes, Larger(stronger) axles and diff, Locker.
Get the factory locker pump from the donor vehicle to actuate the locker. Get the drive shaft as well in order to get the Yoke.
Cons: axle is 3" wider so tires will stick out an inch and a half farther on the side but is hardly noticable.
Swap in Gen 2 coil spring at the same time if desired..
Re: Gen I to Gen II compatability thread [Re: justice] #799901 06/19/07 08:14 PM
As it pertains to the tires protruding farther out, does this have any pro's/con's on or off road?
Re: Gen I to Gen II compatability thread [Re: hazy_daze] #799902 06/19/07 08:37 PM
justice Offline OP
Some say that its a pro in the mud as the back tires have a fresh track to grip as opposed to the front, but at an inch and a half I would say that the benifit would probably be negligable.
Re: Gen I to Gen II compatability thread [Re: justice] #799903 06/20/07 06:42 AM
Bernoulli Offline
Any noticeable handling change attributable to the wider rear axle?
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: Gen I to Gen II compatability thread [Re: Bernoulli] #799904 06/20/07 07:23 AM
StockRaider Offline
I assume off road it will keep it a bit more stable.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Gen I to Gen II compatability thread [Re: justice] #799905 06/20/07 08:29 AM
52degrees Offline
Donor: 96SR
Keep in mind that my 3.5 SR auto to 90 3.0 manual required driveline modifications.
KG6VNX
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6470 MB (Peak: 0.7546 MB) Data Comp: Off Server Time: 2026-06-23 04:52:34 UTC
