Re: Gen I to Gen II compatability thread
[Re: 52degrees]
#799906
06/21/07 01:43 AM
93 Gen II RS at Pick-n-Pull in Rancho Cordova, mostly complete yesterday...FYI <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: rxinhed]
#799907
06/21/07 09:05 PM
I'd like to do some of these suspention beef ups from Gen II parts. My concern, because mine's a D.D., is the --effects on handling-- with the wider rear track on my SWB.
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
[Re: justice]
#799908
06/21/07 09:54 PM
OK So it looks like lordtrunks confirmed the Front brake calipers from a Gen 2 will swap over with brake line modification. This most likely only applies to 6 cyl gen 1's. For clarification, this is the hard lines only? Are the hoses the same? I'm replacing my hoses when I do the switch with a set that is a couple inches longer, in preparation for a body lift <img src="/forums/images/graemlins/smile.gif" alt="" /> And, can I just replace the calipers and pads? Or am I the guinea pig on this <img src="/forums/images/graemlins/lol.gif" alt="" /> I'm trying to get it done without replacing my rotors (less than 5k on em) Any input to firm this up?
[Re: hazy_daze]
#799909
06/22/07 02:23 AM
The hoses dont go through the body so adding longer hoses in preperation for a body lift will be of no benefit. Hard lines pass through the body connect to hose at a bracket on the frame (top of shock mount) then on the A arm and from there connect to a nother hard line at a bracket on the caliper. since the hoses dont pass through the body you will gain nothing with a longer hose. Gently bend the hard line where it passes through the body to accomodate the body lift.
The short hard line at the caliper is what Lordrunks is refering to. If you get the hard lines from the donor rig it should be a bolt on swap.
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
[Re: justice]
#799910
06/22/07 02:39 AM
Just went out to my Monty and took a peek, for reference. I understand the short hard line at the caliper. Am I understanding correctly that longer hoses are not necessary or beneficial when doing a body lift? I'm a bit confused on this, been years since my last body lift. But I was thinking that the brake lines/hoses are attached somewhere on the body. So, if you go up with the body, won't you need longer brake lines/hoses <img src="/forums/images/graemlins/confused.gif" alt="" />
[Re: hazy_daze]
#799911
06/22/07 02:49 AM
[Re: hazy_daze]
#799912
06/22/07 02:55 AM
Just went out to my Monty and took a peek, for reference. I understand the short hard line at the caliper. Am I understanding correctly that longer hoses are not necessary or beneficial when doing a body lift? I'm a bit cnfused on this, been years since my last body lift. But I was thinking that the brake lines/hoses are attached somewhere on the body. So, if you go up with the body, won't you need longer brake lines/hoses <img src="/forums/images/graemlins/confused.gif" alt="" /> What Im saying is the Hard lines pass through the body and they have to be gently bent in order to center them in the hole in the inner fender. The hoses (or soft lines) dont connect to the body at any point.
[Re: justice]
#799913
06/22/07 02:58 AM
Ok, read the archived post about the body lift AGAIN for the millionth time. So, by reposting the link to that thread, is that a no to longer brake line/hoses? Because a few lines down from the original post, it says be sure to disconnect the fuel line support bracket. Isn't the fuel system also connected to the body and the frame? What about the fuel filler neck? Is there slack or does it need to be lengthened?
[Re: justice]
#799914
06/22/07 02:59 AM
Crap, you posted again while I was posting <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: hazy_daze]
#799915
06/22/07 03:00 AM
Maybe you should start a new thread with all of your body lift questions so we could try and stay remotely on topic? <img src="/forums/images/graemlins/kewl.gif" alt="" />
