Page 8 of 10 1 2 6 7 8 9 10
Re: Gen I to Gen II compatability thread [Re: yankee7809] #799956 11/19/08 11:32 PM
KrzyDav Offline
On oil cooler , I've used a big AT cooler out of a Mighty Max,,,,an AT cooler from a Gen 1,,, now I've got one from a 94 Diamante . It just depends on what shape will fit in the space you have to place it. Get a strap of metal from the hardware store and bend and drill your own brackets.
I'd stick with mitsu brand coolers to keep with the bango fittings. Also a "good $40 " tubing benden and some propane will allow you to ajust your steel tubing if needed.
dave h.
Re: Gen I to Gen II compatability thread [Re: KrzyDav] #799957 11/20/08 05:31 AM
HOLLYWOODTHARAIDER Offline
what monteros had lockers stock? can you tell without getting in the rig?
89 raider, 4.3l v6, 700r4 trans, 3in BL, Gen II springs, t-bar crank, Gen II UCAs, custom front bumper, 31-10.50 Baja Claws, Alum wheels
Re: Gen I to Gen II compatability thread [Re: HOLLYWOODTHARAIDER] #799958 11/20/08 06:54 AM
justice Offline OP
Some 92/93 models, most of the 94-97SR models, and 98-2000 models with the "cold weather package."
Re: Gen I to Gen II compatability thread [Re: justice] #799959 11/20/08 07:31 AM
so one wouldn't be in an 01 Montero sport?
Re: Gen I to Gen II compatability thread [Re: HOLLYWOODTHARAIDER] #799960 11/20/08 08:19 AM
actually i just out that you can barely even get an after market locker for them.
Re: Gen I to Gen II compatability thread [Re: HOLLYWOODTHARAIDER] #799961 11/20/08 10:22 PM
KrzyDav Offline
On AllData they show a rear "Hybrid /LSD locker" , w disc brakes on the 4x4 01-03 M.Sport. with 4.9 ratio.
dave h.
Re: Gen I to Gen II compatability thread [Re: KrzyDav] #799962 11/25/08 08:04 AM
I see in one of those first pictures the bump stops are taken off does that hurt any thing?
Re: Gen I to Gen II compatability thread [Re: HOLLYWOODTHARAIDER] #799963 11/25/08 09:21 AM
StockRaider Offline
My bump stops rusted off my Montero LWB and it didn't make a difference. I did notice a thud when I really bottomed out hard once or twice.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Gen I to Gen II compatability thread [Re: StockRaider] #799964 11/27/08 05:35 AM
its not hard on the cv? What about trimming them? what would be the best way to trim them? do Gen II UCAs have bigger bump stops?
Re: Gen I to Gen II compatability thread [Re: StockRaider] #799965 11/30/08 01:48 AM
KrzyDav Offline
I need some clarifacation and refreshing on front pumkin swaps,,,,,
I understand the Gen 1 v6 front pumpkin has a bigger gear than the Gen 2 3.0s.
I guessing a gen 2 pumpkin will fit into a gen 1,,,???????
dave h.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6505 MB (Peak: 0.7533 MB) Data Comp: Off Server Time: 2026-06-22 07:36:33 UTC
