1st gear not staying engaged #8002 02/25/03 04:59 AM
mwhite Offline OP
I am looking at buying a 89 YJ, It has a I6 258 not sure about
trans and transfer case, The gear shift will not stay in first gear
it keeps popping out. any ideas
The YJ is priced right.
88 Mighty Max 2.6 (170,000miles)
3 body lift, 1 1/2 torsion lift, lower bumpstops, 4.625
gears, 31 1/2 buckshot radials,warn 8274
Re: 1st gear not staying engaged #8003 02/25/03 06:42 AM
You have a peugot transmission. It is a piece of crap. You are lucky to get 50-60k miles out of those. I believe a swap with an AX-15 is a straight bolt on, but you may have to do some more research. I would definately swap something in and not rebuild it.
Good Luck
Chip
Re: 1st gear not staying engaged #8004 02/26/03 03:56 AM
I'll second the worn out Peugot. These are junk transmissions, and you will probably not find a good used one. Rebuilding it would cost almost as much as swapping a better transmission into the Jeep.
The AX15 is a direct bolt up, except that you probably have a 21 spline input shaft on your transfer case and the transfer case on the AX15 is probably 23 spline. Solution --- > get the transfer case with the AX15 and swap both in at the same time.
Being a Jeep, the AX15 is not the only solution. There are more swap possibilities for Jeeps than for any other vehicle. Take a look at Novak's web site to get some ideas for other transmission swaps. Advanced adapters Also has a lot of stuff for Jeep transmission swaps.
Or you could put in a Chrysler 3 speed automatic with the AMC engine bolt pattern on it. That's a junkyard find, but the clocking on the transfer case may be off depending on what you pull the transmission from.
Or you could drop a different engine into it and a different transmission at the same time. Small block chevy and a turbo 350?
PHP: 7.4.33 Page Time: 0.013s Queries: 14 (0.010s) Memory: 0.5880 MB (Peak: 0.6416 MB) Data Comp: Off Server Time: 2026-11-17 05:54:48 UTC
