Page 3 of 15 1 2 3 4 5 … 14 15
Re: Moab Countdown Thread [Re: Jim_Paget] #800312 04/05/07 04:48 PM
BigSwede Offline
Are you talking about notching the crossmember for front driveshaft clearance due to diff drop?
Jerry sez that crossmember doesn't do much frame-wise and doesn't have to be very strong...BUT it does have to hold up if you land it on a rock. Folding it up into the driveshaft would be bad...
Only 4 wrenching weekends left before Moab! And I will be out of town for at least one of them... <img src="/forums/images/graemlins/zombie.gif" alt="" />
Serenity now!
Re: Moab Countdown Thread [Re: BigSwede] #800313 04/05/07 05:09 PM
lttlbddy Offline
[color:"red"]41 [/color]
Yeah, I'm a little worried about my spare tire that way...with less backspacing it sits out off of the door further and might be vulnerable in extreme situations...
Does your have mounts for a roof rack? Lots of room up there for a Hi Lift.
Re: Moab Countdown Thread [Re: lttlbddy] #800314 04/05/07 05:18 PM
BigSwede Offline
Not sure...the RS might have the same threaded holes under the rubber trim on the roof that the 4-doors do, and a rack can be adapted onto those, but I would like to keep the center of gravity as low as possible.
A rack would preclude fitting in the garage, too.
Serenity now!
Re: Moab Countdown Thread [Re: BigSwede] #800315 04/06/07 04:47 AM
Jim_Paget Offline OP
Yes, I am notching it, but I am also going to plate it to reinforce the notched section. This is the same approach that Sean and Michael took to this problem.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Moab Countdown Thread [Re: Jim_Paget] #800316 04/06/07 10:27 PM
BigSwede Offline
[color:"red"] 40 [/color]
Just wish it was warmer here for wrenching...only 26 today, a record low for a high. Tomorrow my buddy and I are starting the front end swap work, but may be hampered by numb fingers... <img src="/forums/images/graemlins/zombie.gif" alt="" />
Serenity now!
Re: Moab Countdown Thread [Re: BigSwede] #800317 04/07/07 07:14 AM
This winter I picked up one of those heaters that mount right to the top of a propane tank. Does a great job of heating a 3-car garage when the temperature is in the 20's.
Jim Paget
www.rrr4x4.com
Re: Moab Countdown Thread [Re: Jim_Paget] #800318 04/07/07 07:04 PM
Paddler Offline
Don't you have to vent those?
1995 Honda Passport;
Some people wait a life time for their ship to sail in, while others simple grab the oars and begin paddling
Yours truely
http://www.zutah.com
Re: Moab Countdown Thread [Re: Paddler] #800319 04/08/07 01:13 AM
BigSwede Offline
[color:"red"]39 [/color]
I would definitely have a carbon monoxide monitor out there with you.
We had a halogen light in there with us today, and that sucker warmed the garage by 15 degrees...went from about 30 at the start to 46 by the end, made it almost comfortable.
Got the upper control arms swapped out today. Of course it took longer than I had hoped, but not as long as I feared (We did get it done after all <img src="/forums/images/graemlins/drunk.gif" alt="" /> ).
It took a 24" breaker bar and an assist from the Hi-Lift handle to break the bolts loose...twisted one half-inch extension into taffy, had to go buy a longer extension also...and a flare nut wrench for the brake lines that had to come off to get the control arm off, which did not prevent us from rounding off one of the flare nuts. A small pipe wrench was our salvation there.
In other words, situation normal <img src="/forums/images/graemlins/shiner.gif" alt="" />
Serenity now!
Re: Moab Countdown Thread [Re: BigSwede] #800320 04/08/07 05:00 AM
I open the double car door about 8 inches. It still does fine heating the space, but my garage is fully insulated.
Good point about the CO monitor. I will pick one up tomorrow.
Jim Paget
www.rrr4x4.com
Re: Moab Countdown Thread [Re: Jim_Paget] #800321 04/08/07 05:05 AM
Triathlete Offline
Wow, it was 86 degrees and sunny here! I even broke down and washed my VX today...first time in about 5 months I think. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Billy
VEHICROSS.INFO
'99 Vehicross 3"OME lift Torsion bar crank Ball joint flip 31" BFG AT's (everyday)/MTR's (wheel'n) Trooper skids OBA...more to come!
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.010s) Memory: 0.6492 MB (Peak: 0.7586 MB) Data Comp: Off Server Time: 2026-11-02 11:00:34 UTC
