I'll second the worn out Peugot. These are junk transmissions, and you will probably not find a good used one. Rebuilding it would cost almost as much as swapping a better transmission into the Jeep.
The AX15 is a direct bolt up, except that you probably have a 21 spline input shaft on your transfer case and the transfer case on the AX15 is probably 23 spline. Solution --- > get the transfer case with the AX15 and swap both in at the same time.
Being a Jeep, the AX15 is not the only solution. There are more swap possibilities for Jeeps than for any other vehicle. Take a look at Novak's web site to get some ideas for other transmission swaps. Advanced adapters Also has a lot of stuff for Jeep transmission swaps.
Or you could put in a Chrysler 3 speed automatic with the AMC engine bolt pattern on it. That's a junkyard find, but the clocking on the transfer case may be off depending on what you pull the transmission from.
Or you could drop a different engine into it and a different transmission at the same time. Small block chevy and a turbo 350?
