Page 3 of 3 1 2 3
Re: 3.0 Radiator in 22re [Re: grandeyota] #800505 04/16/07 04:44 PM
grandeyota Offline OP
I ended up using the plug for the clock to power the switch. It has a 12V+ that is active when the key is in ACC position.
I was searching for somewhere to plug in the temp sensor from summit and saw this picture in a post on pirate:
(the circles and questions are from the original post, not my edits)
The thermostat housing I have now doesn't have that sensor that is circled in red. What I want to know where I could find a t-stat housing like that, or a part number? I'd feel alot more comfortable with a housing that was made to have a sensor in it than drilling/tapping the existing one, it's a little thin.
Fur clog in the sausage grinder
Re: 3.0 Radiator in 22re [Re: grandeyota] #800506 04/16/07 08:51 PM
DRTDEVL Offline
That is the intake from an earlier 22RE (85-87/8)... The sensor is used to bump up fuel pressure when hot starting the engine.
Not the best location for a fan controller. If the thermostat is sticky, the fan could be fooled by a lower reading than actual engine coolant temp, and not activate the fan.
Use the engine block drain, 3/4 of the way back on the driver's side of the engine, low on the block... Gives you a more accurate temp reading.
Re: 3.0 Radiator in 22re [Re: DRTDEVL] #800507 04/16/07 11:46 PM
Oh heck yeah, I forgot about that drain plug. Thanks! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 3.0 Radiator in 22re [Re: grandeyota] #800508 04/18/07 07:21 PM
Just a quick question on the block drain plug. What is the thread size/pitch?
It not something I can really take out and check without making a bit of a mess <img src="/forums/images/graemlins/smile.gif" alt="" />
The sender is 3/8-18 NPT and I'd like to know if I need an adapter for it to fit in there.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 2.007s Queries: 16 (0.004s) Memory: 0.6095 MB (Peak: 0.6820 MB) Data Comp: Off Server Time: 2026-06-16 08:32:31 UTC
