Which specialized tools or Toyota SSTÆs are worthwhile?
#800524
03/26/07 04:18 PM
Which specialized tools do you find you use maybe once a year but save you lots of grief? I just did my rear brakes and would have killed for a tool to help with the shoe retaining springs.
What special tools do you use? Which ones would you recommend getting? I find the c-clips on the front axles are usually tricky to get off. Anything better than snap-ring pliers and a small screwdriver to use on these?
1988 4Runner, V6 Auto, Mostly Stock 32 x 9.5 Swampers
Re: Which specialized tools or Toyota SSTÆs are worthwhile?
[Re: The_Rusty_Gear]
#800525
03/26/07 05:22 PM
These, Marlin sells them, but you can find them elsewhere. Snap Ring Pliers Removing the snap ring from inside the hub when doing trail side Birfield repairs can be quick and easy, or a hours long ordeal if you don't have the right tools. These high quality Proto Tool snap ring pliers make it easy to reach into the hub and remove the stub shaft C clip. Also useful for transmission servicing. MC-17102, Snap Ring Pliers, $24.95 ![[Linked Image]](http://www.marlincrawler.com/images/ring_pliers_200.jpg)
"Serenity through Sobriety"
#800526
03/26/07 05:24 PM
[Re: 4Crawler]
#800527
03/26/07 08:21 PM
i got frustrated with my cheap snap ring pliers and screwdrivers, so i broke down and bought a set of lock ring pliers from sears. much nicer!
'79 sport 4x4 longbed <img src="/forums/images/graemlins/smile.gif" alt="" /> 20/22R hybrid with EB's OS valves, 268c cam, offy intake, weber 32/36, thorley header, 5 speed swap, 34" LTBs, downey 3" springs, marlin hysteer, 4.88s and locked
'91 4x4 shortbed 22R-E, W56, the dd!
#800528
03/26/07 08:39 PM
Yes, the brake tools save a TON of time. Also a 54mm thin wall socket for the wheel bearing nuts up front are a must.
-Scerb
[Re: Scerb]
#800529
03/26/07 09:46 PM
On the brake retaining springs, I've found that if you lightly grab the cup with some vice-grips it's easy to put them on. Of course I found this out after my fingers were raw from doing the first side.
Ryan
[Re: Ryan_Vazquez]
#800530
03/27/07 04:11 AM
There is an SST to center the birfs/axle in the front housing... Saves the seals.
22REturbo.net 1988 4Runner 22RTE core, turbocharged, megasquirted...
#800531
03/27/07 05:11 AM
Ditto snap ring pliers and 54mm hub socket. You need a 1/2" to 3/4" dr adapter to go with that too.
My others:
*My universal brake tool *Reverse drill bits (more forgiving than extractors) *Nut splitter for the rusted/rounded stuff *My 1/2"dr x 36" extension and 14mm/17mm toggle sockets for tranny work <img src="/forums/images/graemlins/kewl.gif" alt="" /> *Gearwrenches; if you don't have air tools, at least have these! *Blacklight flashlight--for those elusive leaks *metric allen set *BJ pickle fork *1-1/2" x 3 ft pipe for leverage <img src="/forums/images/graemlins/cyclops.gif" alt="" /> *Craftsman 1/2"dr torque wrench, 25-650 ft-lb *Little cheapie Autotron multimeter *brass drift set
[Re: kewlynx]
#800532
03/27/07 03:20 PM
My others:
*My universal brake tool *Reverse drill bits (more forgiving than extractors) *Nut splitter for the rusted/rounded stuff *My 1/2"dr x 36" extension and 14mm/17mm toggle sockets for tranny work <img src="/forums/images/graemlins/kewl.gif" alt="" /> *Gearwrenches; if you don't have air tools, at least have these! *Blacklight flashlight--for those elusive leaks *metric allen set *BJ pickle fork *1-1/2" x 3 ft pipe for leverage <img src="/forums/images/graemlins/cyclops.gif" alt="" /> *Craftsman 1/2"dr torque wrench, 25-650 ft-lb *Little cheapie Autotron multimeter *brass drift set What's a toggle socket?
#800533
03/27/07 03:29 PM
I'll guess it's a 3/8 or 1/2" drive that has the ability to work at an angle, not just straight-on from the wrench.
'80 4X4 Longbed
