Question on tire size
#800595
03/27/07 12:35 AM
Need to replace the tires on my 2002 Tracker/Vitara soon. The original tire size is 215/70/R15. Now I want to get a set of AT tires. But there are non in that size. I could either go with: - 215/75R15 - 225/70R15
AT tires are available in both sizes. Which size is the better choice? In both sizes the speedometer will be off a little. But not so much as it would be a concern with me. Would the 225 cause trouble because it is wider by 1cm? Rubbing somewhere when the steering wheel is turned all the way?
2001 Trooper
Re: Question on tire size
[Re: Harhir]
#800596
03/29/07 12:52 AM
I have a 1998 Sidekick sport and it has the 225's on it and I do not have any turning issues. One thing to consider is the 215's have less surface friction and less weight which will usually give you better fuel milage.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5858 MB (Peak: 0.6336 MB) Data Comp: Off Server Time: 2026-06-17 05:28:12 UTCValid HTML 5 and Valid CSS
