Page 3 of 3 1 2 3
Re: Rock lights [Re: Angelo] #800633 03/29/07 02:28 AM
icysyrup Offline
If someone were to wire up these lil LED lights under the hood, how would one do it? Is it that simple?
They just have 2 wires.....a power and ground...they have the resistor already built into the wiring......I might just do that on the engine compartment with one...One would be more than bright enough to light up under there....
03 Montero XLS, OME 2"suspension lift,Full skid plates, Extended Diff/transfer breathers. 34 LTB's, Winch w/syn rope, Locked front/rear.
Re: Rock lights [Re: icysyrup] #800634 03/29/07 04:12 AM
Robinhood150 Offline
No way you're going to break an LED, they're embedded in epoxy and are practically impervious to vibration.
You can run these over, spray them with gravel, probably even shoot them with a bb gun and they'd be fine. No glass to break, no filament to burn out or vibrate to death, no worries of water getting into the glass. I can run these all night long with the engine off and I can still start up in the morning. They also seem to attract fewer bugs than normal lights.
I've got 8 LEDs under my truck for a total of about $35.
Steve
My Website ||Gettin' off 4wheel drive club member
'93 4Runner V6 4x4 auto tranny
If you have to ask about a SAS, you're not ready for it.
Re: Rock lights [Re: Angelo] #800635 03/29/07 04:18 AM
It depends on what kind you get. LEDs need around 3V, any more than that and you'll toast them. Some over the counter LEDs come with resisters in them to reduce the voltage. I made mine from scratch and went a little more sophisticated and used a current regulator IC chip.
There are a ton of websites showing how to calculate the resistor needed for LEDs.
Steve
Page 3 of 3 1 2 3
Moderated by  4x4Wire, Dandeman, Mike Bondi
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6011 MB (Peak: 0.6555 MB) Data Comp: Off Server Time: 2026-07-17 07:48:23 UTC
