Rear D ring mount
#800666
03/27/07 04:14 AM
I'm sure you've all seen the D ring mount that goes in your rear 2in receiver. Well, I saw a truck driving down the road yesterday that had a D ring mounted through the hole you would normally put the ball in on a regular ball mount. Anyone see a problem with this? Or are you better off springing for the actual D ring mount? My ball mount is rated for a 5000lb pull, so would putting a D ring through the hole be safe?
Just wondering...
Chris
Re: Rear D ring mount
[Re: Chris72]
#800667
03/27/07 01:52 PM
If I understand the question correctly.... I would say no. The ball mount is rated according to its function,which is being bolted down tight. A D-ring ( and this is where I got lost) is bolted but pivots and moves causing stress friction that ball mount might not handle.
Better safe that sorry, right?
Who uses a d-ring ? ....The farmer who pulls me out of his corn field with a tractor
1989 5 door montero 3.0 auto stock original Japanese about 200k miles
[Re: generation_one]
#800668
03/27/07 03:39 PM
You understood it correctly, and your answer makes sense... I was just curious. I was driving across Iowa on Sunday and saw a D-Ring mounted that way and it just made me wonder...
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5895 MB (Peak: 0.6427 MB) Data Comp: Off Server Time: 2026-05-30 19:13:15 UTCValid HTML 5 and Valid CSS
