tube frames
#800883
03/28/07 03:32 AM
I have a 2003 tacoma. I want to chop off the bed and replace it with a tube frame and roll cage. I know that I will need and fuel cell and place to mount lights and a plate. I have a basic idea of how I want it to turn out. The only questions that I have are: Are there any recommendations for what size tube I should use (OD and thickness, I want to use an aluminum alloy?) I live in North Carolina and I am wondering about the legalities of not having a rear bumper? Has anyone else looked into doing this or have any suggestions?
Re: tube frames
[Re: RCFoster]
#800884
03/28/07 10:25 PM
Aluminum for a rear cage/chasis? You sure you don't mean Chromoly steel? I would think 1.75" DOM would be sufficient since it sounds like you are just doing this for a trail rig, not a competition rig. I guess if you want to dump the money into 4130 Chromoly, be my guest, though i can't see any benefit for your situation. Sounds like a huge project to me. That's gonna require a lot of expensive tools and a lot of fabrication skills to do it correct.
Good Luck
Re: tube frames
[Re: RCFoster]
#800885
03/28/07 11:43 PM
Yea I don't think you mean aluminum alloy; that could get real nasty real quick! <img src="/forums/images/graemlins/scared.gif" alt="" />
'99 Tacoma Xtra cab V6 TRD TRD Supercharged, URD 7th injector and 2.2" pulley, 32X11.5 BFG All-Terrains, OME 881 3-inch lift/Toytec AAL, 5100 Series Bilsteins all around, and ProComp 130 lights. No I'm not some creepy naked guy...
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5925 MB (Peak: 0.6459 MB) Data Comp: Off Server Time: 2026-06-01 13:05:32 UTCValid HTML 5 and Valid CSS
