Re: Shackle lift Vs. Add a leaf on 92 mitsu mighty max [Re: CapnCrunch] #800955 03/29/07 02:41 PM
Quinnchuck Offline
So,,a guy needs the shackel kit ,longer shocks & brake line.What shocks are they for or from?The brake line same question or is it custom made? <img src="/forums/images/graemlins/notooth.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
"YOU CAN ONLY LEARN SO MUCH KNOWLEDGE IN A LIFETIME..BUT IMAGINATION IS WHAT MAKES THE WORLD GO AROUND"
89 POWER RAM D50 4X4 XCab 2.6L
91 Grand Prix GTP 3.4L
87 Jeep YJ Laredo 4.0L EFI
Re: Shackle lift Vs. Add a leaf on 92 mitsu mighty max [Re: don] #800956 03/29/07 04:48 PM
CapnCrunch Offline
man, you have the best built up 2.6 rig on the planet!
Don, you're making me blush! Thanks man, but I think there are a few others that edge me out.
How is the UCA swap? Steering?
UCA swap went well and was relatively easy. Steering is good. Braking is great...much better than before.
The shocks I have are Old Man Emu Nitrocharger shocks. I can't remember any part numbers or such, but I'll see if I can dig it up somewhere.
The brake lines are custom made steel-braid brake lines and I had them made long enough to accommodate a 2" suspension lift.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: Shackle lift Vs. Add a leaf on 92 mitsu mighty max [Re: Quinnchuck] #800957 03/29/07 07:07 PM
powerRam50 Offline
on the trucks my brake lines are long enough and i have had no problem with the stock shockes.
Re: Shackle lift Vs. Add a leaf on 92 mitsu mighty max [Re: powerRam50] #800958 03/29/07 07:39 PM
mountain_warrior Offline
wouldnt yours be the same as my 88 monteros? so i dont have to get new shocks or brake lines? <img src="/forums/images/graemlins/smile.gif" alt="" />
1988 swb montero/pajero
1995 sr montero
Re: Shackle lift Vs. Add a leaf on 92 mitsu mighty max [Re: mountain_warrior] #800959 03/29/07 07:49 PM
CapnCrunch Offline
As Don mentioned above, you will want longer shocks and longer brake lines. After the suspension lift (shackles or leafs, and t-bar crank w/bump-stop trim), when you max out your drop you will be bottoming-out your shocks. If you get longer shocks, then you will be putting tension on your brake lines.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: Shackle lift Vs. Add a leaf on 92 mitsu mighty max [Re: CapnCrunch] #800960 03/29/07 10:03 PM
are the ones you have like the ones toward the bottom of this page??? http://www.rocky-road.com/montero.html
1995 sr montero
Re: Shackle lift Vs. Add a leaf on 92 mitsu mighty max [Re: mountain_warrior] #800961 03/29/07 11:35 PM
CapnCrunch Offline
If you're talking about shocks, yes, as I mentioned above they are Old Man Emu Nitrocharger shocks.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: Shackle lift Vs. Add a leaf on 92 mitsu mighty max [Re: shorepig] #800962 04/06/07 02:34 AM
FlaRaider Offline
I've got all the parts for a shackle lift if anyone's interested in a good deal.
Dave
87 Raider - adopted by a new family
89 Raider - sole survivor
88 Montero - adopted by a new family
89 Montero - organ donor - R I P
90 Montero lwb - organ donor - R I P
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.005s) Memory: 0.6309 MB (Peak: 0.7252 MB) Data Comp: Off Server Time: 2026-06-23 03:11:36 UTC
