Re: Hard to start engine cold [Re: Altuve] #801182 03/30/07 01:28 PM
TitusCanbee Offline
On that EGR valve, you should also check to see if its leaking. With it off, spray some thin solvent (I used carb cleaner) into one of the exhaust passages. It should not leak past into the other side, if it does, exhaust is leaking all the time, too. This was the problem on my '89, I elected to block off the supply on the exhaust manifold and delete the EGR <img src="/forums/images/graemlins/evil.gif" alt="" />. Truck starts and runs much better - better gas mileage also. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'89 Montero, '90 Montero, both 3.0s and 4drs.
'08 Chevy HHR
Re: Hard to start engine cold [Re: TitusCanbee] #801183 03/30/07 07:15 PM
A
Altuve Offline OP
Hey gen one, its a rare model, it uses 3.0 v6 12valve engine, 5 Sp manual tranny, a part time 4WD non super selec or active trac, no LSD or Locker just plain and simple, This model called V13, is common in central and South America, Leaf spring, 4.625 diff ratio, 1.925 low range, manual Aisin hubs, very reliable truck, never let me down, it has 270.000 km. on the original motor just valve seals once and 3 timing belts, rock solid engine. I will post a pics but I'm trying to figure out how? How do you attached images?? Thank for your help.
Montero 98, 5sp manual, Leaf Sprung, SWB, 3.0 V6 engine 12valve, 32" Kumho MT, custom bull bar, custom snorkel, 3 inch lift, KC highlight, 4.625 gears, 1.925 Low, part time 4WD non super select or active trac.
Re: Hard to start engine cold [Re: Altuve] #801184 03/30/07 07:21 PM
G
generation_one Offline
if you want to post a pic.
look on this page:
http://www.4x4wire.com/forums/faq.php?Cat=
its to hard for me....I gave up trying.
I thought maybe you meant '89 instead of '98...cool
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: Hard to start engine cold [Re: generation_one] #801185 03/30/07 07:25 PM
G
about 200k miles
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6085 MB (Peak: 0.6644 MB) Data Comp: Off Server Time: 2026-06-20 13:41:41 UTC
