Cowl seal install.... #801211 03/29/07 12:15 PM
9
93yj Offline OP
Hey guys, when I go to replace the windshield frame does the cowl seal need any silicone or RTV or does it get put down dry? The last time I replaced it (in hopes of saving my windshield frame which didn't work) the seal came w/o any information so I had no idea. This time I want to make sure I do it right.
Re: Cowl seal install.... [Re: 93yj] #801212 03/29/07 02:55 PM
BigJim Offline
As long as it is in there and don't leak you are Ok. If I WAS gonna pooky it I'd pooky it in place overnight before installing the windshield.
Re: Cowl seal install.... [Re: 93yj] #801213 03/29/07 03:41 PM
BobRowe Offline
If you're not going to be lowering your windshield, I wouldn't use any adhesive on it.
But if you routinely lower your windshield, it's kind of a PITA to have to store it and then align it every time you raise the windshield again. If that's the case, I'd use silicone or contact cement to fix it to the cowl. Wouldn't take a whole lot -- just enough so that it stays in place when you lower the windshield.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5908 MB (Peak: 0.6436 MB) Data Comp: Off Server Time: 2026-07-13 17:09:53 UTC
