Re: Slip Yoke Travel on front DS [Re: missouriman] #801270 03/30/07 03:41 AM
Dingman Offline OP
Hmmm, I don't know about the dust cap. I see a shoulder on the male end that the edge of the female end stops at. I almost thought about grinding that shoulder, and moving it towards the u-joint, but wasn't sure how deep the female end is. are you saying the female end is way deeper than the male end?
Paved Roads ~ Another example of wasteful government spending.
'85 $runner, lifted and locked.
See the Ding_yota here
Re: Slip Yoke Travel on front DS [Re: eightyeight] #801271 03/30/07 05:22 AM
OOP'S Offline
i cut down a rear driveshaft to make my front. stock slipshaft, maybee 6" travel. i have yet to drop it with my TG front springs.
Let me drive it, I will get it to come apart. Stock length is just not long enough. I was on the Con one weekend and this guy was bragging about running a stock length slip. Going down the Big Sluice he was pretty flexed out, there was a loud bang. When I got there, he had broken the front output shaft out of the t-case and the d-shaft was bent. What happened was the slip was almost out and as it started to compress the male part of the slip cocked in the female part, did not slide back in so something had to break/bend and both happened, busted t-case, bent d-shaft.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Slip Yoke Travel on front DS [Re: Staceman] #801272 03/30/07 05:20 PM
Dingman Offline OP
Thanks, I do have crossover and I've already moved the axle forward 3-4". I think I need to check on the kit from Marlin.
Re: Slip Yoke Travel on front DS [Re: OOP'S] #801273 03/31/07 05:51 AM
eightyeight Offline
i did not say its not possible to drop it, i said i haven't yet. i know its not the best setup, but it has worked so far. i dont think it will drop out. maybee if a lot of torque is applied when it is fully dropped the splines may be damaged, and what your saying could happen. a rear slip shaft is longer than a stock front btw.
i wail the everliving crap out of my truck. and it hasnt broken yet.
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: Slip Yoke Travel on front DS [Re: eightyeight] #801274 03/31/07 02:24 PM
Dingman Offline OP
Well, I've ordered the longer slip from Marlin. I could have done the square tube but I'll try this first.
I've also run the stock slip for about a year and mine fell apart one time, going up a steep hill.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6127 MB (Peak: 0.6783 MB) Data Comp: Off Server Time: 2026-07-14 08:18:03 UTC
