rear wheel bearing - tapered or cylindrical? #801528 03/30/07 07:28 PM
mceachrw Offline OP
1998 Rodeo S, 3.2, 2wd, 5 speed
changing the rear wheel bearing in order to change a leaking seal. got the axle out and the bearing is tapered. i bought the bearing below because it was what all the online parts stores said i needed.
bearing from rock auto
this bearing is cylindrical and not tapered. the od and id are correct. also, the retainer is a lot thicker than the one i just pulled out. anyone know the part number i really need? i would like to buy locally from oreilly's, napa, or autozone if possible. last resort, i'll get one from st charles.
Re: rear wheel bearing - tapered or cylindrical? [Re: mceachrw] #801529 03/30/07 07:51 PM
Richard Saylor Offline
If you've already got the bearing out, just take it with you to the parts store. It should have a number on it somewhere. Nothing else, they should be able to get the book out and match it up by measurements. Personally, I'd go to O'Reilly's or Napa for it. I KNOW they've got the books. Autozone really doesn't. They're more of, if it ain't in the computer, we can't get it.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: rear wheel bearing - tapered or cylindrical? [Re: Richard Saylor] #801530 03/31/07 08:01 PM
mceachrw Offline OP
went ahead drove 45 minutes to the closest isuzu stealer and paid $100 for their kit. for future reference, the bearing and seal numbers follow:
Rear wheel seal - C|R 18731
Rear wheel bearing
Timken - U360L 097
Timken - U399 097
the following from napa looks to be the same, but i did not get one to see for sure.
kit from napa
Re: rear wheel bearing - tapered or cylindrical? [Re: mceachrw] #801531 04/01/07 05:13 AM
trooperbc Offline
for future reference, was this the isuzu part number for the 'kit'
8-97081-945-0
http://www.myisuzuparts.com/part_info_popup.php?part=8-97081-945-0
thanks
//bc
1992 sohc trooper 3.2l v6 automatic . . . as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Re: rear wheel bearing - tapered or cylindrical? [Re: trooperbc] #801532 04/02/07 05:57 AM
mceachrw Offline OP
8-97081-945-0 is printed on my receipt. i left the box at the machine shop. when i pick up the axle tomorrow, i'll ask if they kept the box to confirm.
edit: box was long gone when i went to the machine shop. i am pretty sure the parts monkey would match the invoice to the parts he gave me. i'll stick by 8-97081-945-0.
PHP: 7.4.33 Page Time: 3.534s Queries: 15 (0.006s) Memory: 0.6068 MB (Peak: 0.6722 MB) Data Comp: Off Server Time: 2026-11-14 16:21:58 UTC
