1995 6G72 SOHC need info on rebuild #801599 03/31/07 05:48 AM
darkroom1428 Offline OP
OK i'm needing a new engine. this is going to be my 4th motor on my 1995 Montero and i'm getting tired of dishing out alot of cash on a rare motor.
so i'm wondering if it would be possible to use and older 6g72 block and just swap cylinder heads?
Thanks for any help
Re: 1995 6G72 SOHC need info on rebuild [Re: darkroom1428] #801600 04/01/07 12:54 AM
I think you'll be fine with the block, but the compression will probably be wrong, and the pistons for a 3.0 24v sohc are different than a 3.0 12v sohc (valve reliefs and dish volume).
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5845 MB (Peak: 0.6325 MB) Data Comp: Off Server Time: 2026-05-31 04:00:36 UTC
