coolant hose
#802021
04/02/07 01:48 PM
Changed the oil over the weekend and noticed the "u" shaped hose located on the t-stat housing just underneath the upper radiator hose seemed pretty spongy feeling. I assume this is a coolant by-pass hose. When I replace the hose do I need to drain any coolant first? Does the hose normally hold coolant or is is dry when the engine is off? Thanks, Jim Tulsa '89 two door v6 auto
Re: coolant hose
[Re: 'ol trigger]
#802022
04/02/07 01:51 PM
Probably need to let out a gallon or more.
1989 5 door montero 3.0 auto stock original Japanese about 200k miles
Re: coolant hose
[Re: generation_one]
#802023
04/02/07 05:26 PM
Yup. Drain your coolant, otherwise when you pop the hose off you'll end up draining it anyways... <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Eric W.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5938 MB (Peak: 0.6469 MB) Data Comp: Off Server Time: 2026-06-21 00:06:06 UTCValid HTML 5 and Valid CSS
