Re: Best rear axle match for a front d44 [Re: 4xToy] #802274 04/04/07 02:27 PM
matthew Offline
you could also convert the front pretty easily to 5 luf and run a rear 31 spline 9"
'93 RS 3.2L - DD/trail build
'97 7.3L Powerstroke - tow rig
'71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build
Owner: http://www.INDEPENDENT4x.com
m-f 9am-6pm EST. 804-550-0480
Re: Best rear axle match for a front d44 [Re: matthew] #802275 04/04/07 10:59 PM
4xToy Offline OP
Matt, Would it be just as easy to change a 9" to 6 lug? I think I have a 9" out of a car but it would probably be too short
-Chad
Re: Best rear axle match for a front d44 [Re: 4xToy] #802276 04/05/07 03:46 PM
matthew Offline
Yeah, certianly, For the 9" rears, we have blank alloy shafts............at around $100 ea.
they can be splined and drilled to any pattern. runs about $125 to spline and cut to length. then yo mark and drill your pattern....you could also match lug studs to the front hubs.
all i was saying is that for a front 5 lug conversion, you could do it w/ junkyard "finds" vs. making shafts, but either way is totally do-able. <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5984 MB (Peak: 0.6516 MB) Data Comp: Off Server Time: 2026-07-13 07:39:26 UTC
