Looks like i'm going to have to replace a cam. #802309 04/03/07 05:25 AM
DangerCart Offline OP
I'll cut the story and get sraight to the steak and potatoes. Camshaft bolt sheared off on drivers side cam. I was able to get the broken half out but unfortunately I accidently botched the threads. While I'm in taking eveything apart what else should I do while i'm in there?
I already tried to tap the treads but to no avail. I was about to thread to a larger thread size but I think its best to keep everything stock.
1989 Dodge Raider 3.0L with 5-speed.
In limbo of what to do with it.
Re: Looks like i'm going to have to replace a cam. [Re: DangerCart] #802310 04/03/07 03:22 PM
MI_Mitsu Offline
I have a used 3.0L cam in good condition if you need it. It has some visible surface wear in a few spots of I recall correctly but hard to tell with a fingernail.
If interested, PM me and I'll see if I can arrange a few digital photos for you in the next few days.
MI-Mitsu
89 Montero LS 3.0L/Auto
90 MightyMax 2.4L/Man
Parted/gone - parts available!
89 Montero LS 3.0L/Auto [Blue/Blue] (2 of 2)
89 Conquest SHP
88 Conquest SHP
87 Dodge Raider 2.6L/Auto
91 Montero RS 3.0L/Auto
Others: 37 Lincoln
Re: Looks like i'm going to have to replace a cam. [Re: MI_Mitsu] #802311 04/03/07 05:35 PM
Brianawd Offline
does the cam still turn in the head. The only time I ever seen a cam bolt brake like that if the cam seizes in the head. Mitsu 4g63t have that problem some times. I would check to see if the cam did seize.
92 Galant vr4 11.17at132mph
98 Montero 2.5"lift,33/10.50/15,15x8procomp wheels.
trail-gear rock sliders,ARB front bumper,Warn m8000 winch. Piaa lights.
Re: Looks like i'm going to have to replace a cam. [Re: Brianawd] #802312 04/04/07 03:02 AM
Some num nuts did a timming belt job and installed the sprocket on backwards.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6004 MB (Peak: 0.6561 MB) Data Comp: Off Server Time: 2026-06-21 11:18:09 UTC
