Whaaat??? why is there black oil coming from....
#802671
04/05/07 02:10 AM
...my gas tank! I have an 86 Troop. In the center (on the bottom) of the gas tank there is a dran plug. When I park there acummulates a small puddle of pitch black oil(or oily substance) under the dran plug, that smells of gas. And I mean pitch black, it stained my finger even after 2 washings. So I'm really confused. It is definitly under the drain plug, NOT the diff. On the drain plug itself was a clear (no hint of color) liquid that smelled also of gas.
What could this be?
HELP!
Oh and thanks
(Formerly known as Black-n-Blue) 86 Troop --- for Hiking, Mtn.Biking, Camping, Canoeing, and Wheeling too! "...and remember, If women can't find you handsome, they should at least find you handy!" -Red Green
Re: Whaaat??? why is there black oil coming from....
[Re: TrooperBeliever]
#802672
04/05/07 02:58 AM
CHRIS 98 Amigo, 92 Pup
#802673
04/05/07 03:48 AM
Isuzu Moderator
It's also probably dissolving any undercoating, plus the dirt, plus the grime.
Michael
[Re: mlclark]
#802674
04/05/07 05:51 AM
So Is this a leaky gas tank? Is that plug for draining the gas? then do I just need to tighten it up a bit? or is there some sort of washer called for?
thx
#802675
04/05/07 06:21 AM
Isuzu Moderator
Well...you are probably going to have to crawl under there and take a look. I can't quite see it from here.
There is a copper washer under the plug. Easy fix if that is the problem.
Good Luck, Michael
