body lift #802893 04/05/07 07:26 PM
IceBlueT Offline OP
wow....the body lift for my truck came today, and to say the least, im a bit overwhelmed....so many pieces, so many instructions...dang...anyone have any tips as to how to go about putting it on, and anything else that would help?
p.s. finally figured out to get a picture up!! check it out!
formerly 277000_yota
Old enough to know better, but still to damn arrogant to care...
]www.cardomain.com/ride/2614269
'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P)
'98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
Re: body lift [Re: IceBlueT] #802894 04/05/07 07:49 PM
Scerb Offline
Well, theres obviously the body lift pucks w/ longer bolts. Then theres gonna be some radiator drop brackets probably with some bolts. Also bumper lift brackets probably with bolts. MAYYBE a steering shaft extension, but I doubt it.
All there is to it is undo all the body mounts, lift up the body, put the pucks in, and bolt it back down. Either use a jack with a 4x4 piece of wood or get a buddy to help you lift. You'll figure it out <img src="/forums/images/graemlins/kewl.gif" alt="" />
-Scerb
Re: body lift [Re: Scerb] #802895 04/05/07 07:53 PM
IceBlueT Offline OP
thats one of the things i was wondering about. i THINK it has a steering extension, but im not sure. how would you go about putting it on? the instructions arent very clear. also, it says you have to move the transfer case shifter, and like the the steering extension, the instructions arent very clear.
Re: body lift [Re: IceBlueT] #802896 04/05/07 07:57 PM
fourwd1 Offline
You may have to bend or otherwise modify the t-case shifter or enlarge the hole in the tunnel.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: body lift [Re: fourwd1] #802897 04/05/07 08:00 PM
IceBlueT Offline OP
ok, so would you say its easier to cut the tunnel or modify the stick?
Re: body lift [Re: IceBlueT] #802898 04/05/07 08:07 PM
fourwd1 Offline
Most people find it easier to cut the tunnel as needed.
Re: body lift [Re: IceBlueT] #802899 04/05/07 08:12 PM
4Crawler Offline
Re: body lift [Re: 4Crawler] #802900 04/05/07 09:28 PM
IceBlueT Offline OP
ok. what about installing the steering shaft extension? it does have one, but im not exactly sure how it works.
also, thanks 4crawler. i cant access the info now, because im at school. i will look later.
Re: body lift [Re: IceBlueT] #802901 04/05/07 09:35 PM
4Crawler Offline
Likely that is a top extension, goes on the top end of the steering shaft, extension into the clamp, shaft into the extension:
http://www.4crawler.com/4x4/ForSale/Docs/BodyLift_HowTo.shtml#RecirculatingBall
Re: body lift [Re: 4Crawler] #802902 04/05/07 09:41 PM
IceBlueT Offline OP
thanks
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6434 MB (Peak: 0.7636 MB) Data Comp: Off Server Time: 2026-06-12 17:48:35 UTC
