Some new toys #803345 04/07/07 01:49 AM
L
Lester Offline OP
Hi all
Some new toys I just added to my Pajero:
Gen 2 brakes on a Gen 1-Pic 1
Gen 2 brakes on a Gen 1-Pic 2
Thanks to the WIRE, I have been looking for the swap item for the longest time and yesterday morning, I chanced upon them at my normal garage on a half cut Gen 1 V6. I took some quick measurements and the caliper bolts, brake discs, etc fitted. All I needed for the swap were the brake caliper , caliper brackets, protection plates behind discs, discs with bearing and bearing housing. I used back my brake hoses & hubs. My old bearings were slightly burnt.
ARB switches
ARB switches at centre console
Someone here posted this sometime back and I didn't want to add brackets to the dash board, this is an ideal place for me. At least my kids can't reach for them so easily.
Compressor
Compressor & pressure cut unit
This is a dual piston compressor which I had installed some time back. I hooked it up to a pressure cut set at 125PSI. A 3 Gal air tank is underside above my axle. I used copper pipings to save the hassle of changing and tracing plastic hoses. I got one quick fit coupling at the air tank for general use.
Regulator and pressure switch
This was a T split out from the pressurized line to the regulator set at 10PSI with the pressure switch alike to the ARB.
Locker Axle
Locker Axle
I used back the rear stabiliser from my old axle. I noticed that this axle has both axle shafts being the same length. Both ends of the axle has the numbers '80' on them. This axle has additional clutch plates for the LSD installed. We opened it up as we couldn't turn the axle with one side off the ground. We tot it was stuck.
Dash Light
With the axle locked, I hooked it up to this wheel lock light in my dash. It was really cool. I got this idea from a Thai Pajero I came across.
Re: Some new toys [Re: Lester] #803346 04/07/07 02:57 AM
sparkem Offline
Brakes links not working, have not tried all others yet.
Your links have too much stuff after the .jpg and when I copy and paste that, you are forbidden to look at images, you need to unlock it or something.
Re: Some new toys [Re: sparkem] #803347 04/08/07 01:19 AM
L
Lester Offline OP
Hi Sparkem
I did not have any problem opening the links. Maybe you try it again and let me know. Anyone else? Thanks for informing.
Re: Some new toys [Re: Lester] #803348 04/08/07 01:44 AM
silver94sr Offline
Links don't work.
1994 Montero SR 101,000 JDM 3.5
2" BL, 2.5" Valley Springs Rear Coils
BFG's 33x12.5 MT
Re: Some new toys [Re: silver94sr] #803349 04/08/07 01:50 AM
stony-man Offline
Ditto.
Error 500 'phvrf.yahoo.c...' Unknown Host.
Try reloading the Web page.
Retype the address in your browser.
Check your computer's Internet connection
Re: Some new toys [Re: stony-man] #803350 04/08/07 02:01 AM
mountain_warrior Offline
ya they still dont work <img src="/forums/images/graemlins/drunk.gif" alt="" />
1988 swb montero/pajero
1995 sr montero
Re: Some new toys [Re: mountain_warrior] #803351 04/08/07 04:27 AM
if you click on the link in his sig. you can see all the pictures <img src="/forums/images/graemlins/kewl.gif" alt="" />
1995 sr montero
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6203 MB (Peak: 0.7138 MB) Data Comp: Off Server Time: 2026-06-19 09:24:58 UTC
